will it be Ok to slap one of these in the rear bumper of my 80. It is not for towing its going to be to keep the tailgaters away during rush hour.Also, in case I have to pull a stuck Jeep or LR.
Any towing/trailer supply store has these. They are readily available all over the interwebs. I wouldn't buy anything again from HF. Had some very crappy stuff from them in the past.
I didn't think the factory rear cross member was strong enough to do any hard pulling from. There are four holes there, but I don't think it was to tow from.
Is this on a stock 80 rear bumper or a heavy duty aftermarket rear bumper?
I think that in most places they use the stock bumper with pintle hook for towing. The UN does AFAIK. I think it was just some DOT thing in the US that didn't allow it to be approved for towing. Lame.
I have one. It says 15 tons on it but if I tow anything I use the regular hitch. I use the pintle as extra armor to ward off some of the absolutely insane drivers here in PHX, AZ.
i use one for my m101. works great and enabled me to remove my rock anchor of a hitch. havent tried an extraction yet, but i dont see any problems with it, unless its a bigg a$$ full size belly deep in mud.
the cross member is somewhat hollow though. the top 2 bolts are captured on the inner face of the xmember with welded in nuts, and the bottom 2 require nuts as there is only the outer face (the one visible from the outside) that it attaches to...so its not really double wall strength top to bottom.
I bought one a few months ago to replace my clearance-robbing hitch receiver that I never use. I've only towed with my pintle hitch once, my buddy's '68 Mustang on a car-hauler.
$40 is a good price on a pintle with a ball mount. I found an open box one priced at that in a Boxing Day sale at Canadian Tire. I'd been waiting to find one on sale without much luck at the local farm stores.
An issue with the pintle that you don't have with most standard 2" receivers is where to hook up the safety chains. These are a requirement for towing in most jurisdictions, whatever you feel about the limitations of mounting these on the Toyota-provided rear frame/bumper holes.
I came up with this solution. I bought a 4 foot length of 5/8" chain and added hooks at each end. The hooks are the kind that are open so that they can go hook over the OEM recovery loops that Toyota provides at the left and right ends of the frame. Hung between these two loops, this chain provides a place to hook up your safety chains from the trailer.
For the electrical connector, I used a couple of zipties to make a couple of loops around the bar that runs behind the bumper. This gives me a way to stash the electrical connector up and out of sight unless I need it. I suppose you could install a permanent bracket if you want, but my method leaves the back end clean.
As others have mentioned, be cautious about how big a load you pull or recover with a pintle mounted here. Sure, folks elsewhere pull crazy big loads with these. And just about any of these pintles is rated to pull way more than the 80 is rated to tow in any country. But you don't want things breaking when you're snagging folks out of a stuck and flying through the rear glass, etc, etc.:whoops:
