$13, what a deal. Jackpot -- I'm in WA state so can't pedal that far so would send a box- can get you 15 virtual beers. Looking for miscellaneous stuff for my 75 PIG (bought it two months ago -- needs lots of work) - finally got it running this past Sunday: Sorry list is soooo long but - like I said, jackpot.
1.) rear heater switch
2.) Uncut Dash - mine has been cut (radio)
3.) Front Light posts and bracket - my lenses are OK - bolts twisted off posts - came with rig in a bucket.
4.) Was that a signal/hazard light relay I saw in the bucket?
5.) Loosing electrical strength -- does the harness look in "good" condition
6.) Plastic front vents/nobs
7.) plastic nobs for the lower dash panel (heater/fan slide control nobs)
8.) Accelerator pedal and linkage system - mine has been switched to a cable (poorly rigged and fit to 69 carb -- piece of junk) - I want to go back to the stock
9.) My side mirrors are fogged and dented - are those OK? can new mirrors be fit in them?
10.) Fuse cover plate
11.) Nuts and bolts -- all types -- fasten coil/ignitor bracket to fender
12.) Landcruiser fender emblem (1)
13.) two door release inserts and ashtrays
14.) two window handles, packing and plastic
15.) Carburator cable bracket for my 72 FJ40 --
Can you help me find other stuff that I need for the 75 PIG --
1.) Front windshield molding and windshield -- local glass company can get glass but nobody seems to be able to locate the gasket
2.) Non-USA carb, 75 intake and exhaust manifold - I can run w/o smog stuff. My 75 came with a 69 carb, 69 intake, and header (looks homemade) and attempted to use the stock air-cleaner --- did not work. I borrowed a friends weber 32/34 and got it running. On the highway took it up to 55 mph and looks like the intake exhaust gasket is leaking (exhaust) pretty bad (2F engine). It has a non-USA distributor (vacumm advance) so figured I would go with the Non-USA carb -- SOR suggested this set-up. The way it burns, I don't think the 69 intake manifold should have been used.
3.) Intake/exhaust bolts/nuts
4.) Flexible heater tube - fits up under steering column - just need connector to fit onto blower
5.) Rear side running lights -- if all that is available is the red plastic lens, that is OK
6.) Rear tail light rubber - both sides
7.) Rear reflectors
8.) Front seat headrests
9.) Floor covering - plastic mat - toyota
thanks
Jim Hanson
TLCA 15160 - new member
I haven't been successful at responses so will provide Email address
jdhanson6@msn.com
