LC_Hamma
The Anti-Leafer
- Thread starter
- #541
I fabbed up both axle housing vents, exactly the same, & ran the lines. Rear mounts inside the pass. side C pillar. I've started laying out the wiring for the ARB compressor & it's airline. Also, you can see the wiring started for the front aux. lights.
Yep, I'm gonna do some wiring
I did have a question about the gas tank vent lines. Is it okay to plug both of these or do they need to vent? I already have my rollover vent/ valve located off the gas tank inlet tube.
It has crossed my mind to make one outta tube, but I think the evap tank needs to "expand", which it couldn't do w/ steel
inner handle (perfect length rod) & the upward lift of the outer handle. The only questionable part will be locating the door handle by mounting tabs inside the door shell. Also have to bend up the rod from the handle to the latch. The latches did have a locking mech. but I removed that. I did notice that the door lock knobs from the 90's Honda Civic (handles I'm using) were a perfect match for the
Which is how the top hinge is able to NOT rub the sheetmetal. Now, I hafta hammer & dolly out a small area above the handles for the hinge
You can't tell from the pic, but the bottoms of the handles are bowed out a little.
Next up are the front doors.....
