Pics: How I fixed my steering wheel wobble
SC
The steering wheel in my 03 was wobbling side to side about half an inch and driving me crazy. It would do it with the key out of the truck, so I knew it was something in the column. After doing a little reading on Mud, I decided to order the following parts:
2 bushings, part no. 9038908124
2 bolts, part no. 4585560010
Total cost shipped was about 20 bucks.
The hardest part of this job to me was successfully removing and reinstalling the plastic 2 piece steering column cover. First, extend the wheel all the way out and down. To remove, there are 2 screws, one on each side of the cover facing the driver. You have to turn the wheel to access them. There is also a screw on the underside of the column. Once all three screws are removed, you have to pry the two plastic pieces apart. I had to pry harder than I liked, but it separated. Once the plastic cover is off, two hex head bolts that hold the column must be removed to access the bushings. They are kind of awkward to get to. The best way I figured out was to stick a bit for a driver in the head and then loosen with a wrench. Once the two bolts are removed, the wheel and column will basically fall out of alignment, which allows you to access the bushings. I was skeptical that such a small part could be causing all of the movement, but I pulled out the old bushings, one of which was visibly damaged, and replaced with the new bushings. This was simple. All I then had to do was realign the column and screw the new bolts in using the same method I had to remove the old ones. Once installed and tightened, the side to side wobble was gone. My steering wheel now feels rock solid. Reinstalling the plastic steering column cover is the hardest part. The upper portion has a plastic nub that sticks down inside it and has to stick into a specific place in the column. I forgot to take a picture, but you will see what I mean. It's just a pain to align all the plastic connectors properly without breaking anything. The whole job took me about 15 minutes. Between diagnosing and replacing parts, I imagine the dealer would charge a couple hundred bucks, assuming they didn't try to sell you a bunch of expensive stuff that not needed.
@sacmaster Can I ask if your 03 has the power tilt/telescoping steering wheel?
That's a sweet easy DIY fix right there.
how many miles on your rig?
Just did this on my LX. Took my truck in for an alignment at Lexus (after PepBoys did a terrible job and kept making excuses) and everything went well, except the Tech recommended replacing the steering column due to play!
Lexus quoted me $2,180 for a new steering column and $800 labor! $6.34 for two bushings and its fixed.
Oddly one of the old bushings looked mostly new and the other was a copper explosion. All steering wheel play is gone.
Might do the same on mine too.
Thanks for the post.
5 min fix. All you need is a Phillips head and 6mm allen wrench.
Just don't leave you car on like I did, for an hour and kill your battery.
Has anyone done this on an LC with manual tilt steering? I have everything disconnected, but it feels like the little ball joint in there is connected to the steering shaft and it won't let me tilt everything low enough or get it out of the way to get to where these bushings should be. Also, I don't see any old bushings, possible we don't have them??
I notice an extra vibration in the wheel when I go over something. It's not horrible at all, but it isn't the "solid" feel I would expect. I do feel a slight "clicking" in the wheel when something seems to catch. I wonder if this could be my problem...kind of makes sense based off what I see here and also feel.
I know its nothing with tie rods, steering rack, etc.
What were your symptoms? I am chasing something in my steering and am curious.
When I'd hit bumps the steering wheels would jump around, sometimes to just one side like 10 or 15 degrees, like something was all of a sudden super loose. But on a smooth surface it would feel really tight/normal. Off road it would basically jitter back and forth in a very small arc range like I was getting a ton of loose feedback. Drove me nuts.
Ended up being the lower shaft with the u joint that fixed it for me.
I recently had to replace mine. The u-joint would bind on turns. I should have replaced it along with the rack 2 years ago.
tricky job?
What I am seeing is that my wheel will track straight until I do a tight turn on some undulations; and then the steering wheel will be off center by 5-15* for awhile. I'm not sure what causes it to correct other than doing some sharp turns.
I am also getting a popping noise during some odd turns, and have a bit of play in the wheel. Steering rack and bushings have 50k on them so I don't think I've got an issue there.
When I'd hit bumps the steering wheels would jump around like it was super loose. But on a smooth surface it would feel really tight. Off road it would basically jitter back and forth in a very small arc range like I was getting a ton of loose feedback. Drove me nuts.
EXACTLY what I have felt through the wheel for years...
To confirm, is this the same for a 99LC? No power column.
