Permanently mounted high pressure washer system with heater
Tijeras, NM
Has anyone gone to great lengths at setting up a heated high pressure wash station outside of their garage? I'm talking about using 120/220vac for heater, pump and permanently plumbed in cold water. Basically set up the station on one corner of the garage and then run the hose through the wall using one of them fancy self retracting reels. When you need to use it, just attach the washer wand to the hose and off you go. My garage is heated and insulated so I'd like to keep everything inside, along with the means of draining the system during winter.
