So, I recently purchased my 97 and wanted to do a little PM by replacing the engine coolant. After spending a couple of hours reading the various threads on a DIY flush I was a bit overwhelmed and wanted to go ahead and get it done.
I took the truck to the shop and asked the service rep about what coolant was called for in their system. He told me it says to replace with same color. Knowing that my color was brownish and having read multiple discussions on RED v. GREEN. I felt comfortable going with prestone green, given I didn't have any toyota red. The service rep assured me that the whole system would be completely flushed and refilled with green.
When I returned to pick up the truck I did an initial inspection. When I popped the hood, I noticed that the coolant reservoir was empty. The tech came up and asked if everything was OK and we started talking about the job. After a couple of questions I found out that he had flushed the system and put prestone dexcool (orangish red) in it. I told him that I had read not to use this and that I had asked for prestone green.
The tech was very nice and offered to pull out the dexcool and put in green. I mentioned how it is recommended not to mix colors, so he told me he would flush again to get the dexcool out. He also had been using tap water, which I have read is frowned upon. So I walked to walmart and picked up 2 gallons of distilled water. After a couple hours of using the pressure flusher (running water through, emptying the system, running prestone green and water through, etc.) and learning about the mechanic's past life as an MMA fighter (super nice guy) we were finally seeing mostly greenish fluid in the pressure flusher tubes.
The mechanic then used the pressure flusher to perform the final evacuation of the system (theoretically). He let the car run this time to push the fluid out. So at the point where we believed the system was empty we poured approx a 1/2 - 3/4 gallon of prestone green into the top radiator hose. We then clamped it up and he poured maybe 1/4 a gallon of distilled water into the radiator (using one of the no spill radiator funnels, which supposedly burp the system by themselves). We waited while the engine ran for the radiator to accept more water to no avail.
The mechanic thinks that when he was doing the flush to expel the dexcool with prestone green and tap water that the system filled up and therefore would not accept much additional. Eventually, after taking up several hours of his time I decided to just shake his hand and say thank you.
My questions:
1. Do you think he really flushed the whole system? The heater was never turned on, but I have heard that a pressure flusher should actually not be operated with the heater on.
2. Why did the system accept so little fluid after he thought he had emptied it?
3. Since I was switching from a brownish color (from the PO), to dexcool, to prestone green do I have a recipe for disaster brewing in my system?
4. Should I attempt to perform a flush on my own now or should I be good for another 30k (at which time I will definitely do it myself)?
5. At what level should the reservoir be when hot and cold for an ideally filled system?
My questions:
