Pep Boys Problems
1) if it's a technical job that a kid making 8 bucks an hour could screw up easily, then diy. Especially something as technical as this. Take the time, appears you did your homework, and all of us dedicated to this crack addiction of a hobby can help get you through it.
2) I will never pay for 50/50 or mixed coolant because it's not much difference in price and you're getting half of what ya paid for! I always buy full strength and dilute myself.
3) for flushing purposes only, at home, yes, turn on both heaters and get em flowing. Household water pressure is typically 5-7psi, and a typical radiator cap is 9-13psi, so there isn't worry of overpressurizing the system and doing any "damage" that way. When I do the job, it's usually a drain, fill with the hose, drive 15min, drain, repeat two more times. Then a final drain and check color, should be clear by then. Then add distilled water and coolant, purge the air you can, and go drive it a few minutes to get it up to temp, and a little bit of driving should rock 5he air bubbles out as well. Then I park it and let it cool down, then topping off with coolant. IMO, I'd rather be a bit heavy on the ratio than light. Then go drive for a little while, come home and check a final time, adding if necessary. And as for the resivoir, middle I'd aok, but I tend to go about 2/3, and thats all personal preference. Happy wheeling!
Wow! I'd hate to take showers at your house with only 5-7 PSI of water pressure!
Most home water pressure is typically in the 40 to 68 PSI and has a regulator to keep it under 60 PSI. Then they use restrictors in the showers and faucetts to reduce water usage.
