I decided to replace the hose from the carb to the PCV valve on my ‘64. I haven’t cleaned it in the 2+ years I’ve owned it.
I’ve always read you can shake it to see if it makes a noise to ensure it is clean..which mine does not even after cleaning. After taking mine apart….there is no spring. Should this version have a spring? If so, is there a particular spring I should get? The rubber part might also need a replacement….any replacements for that? On second thought should that rubber piece even be in there? There is no way anything gets past it when in there.
Any thoughts??
Any thoughts??
