Part Questions
AZ
Will tail lights, front turn signal lights, and grille from a 91 Land Cruiser fit a 96?
The grill and front turn signals I don't think will fit. The rest I'm not sure about.
You can probably get the grill and front turn signals to fit with some modification though.
I called Toyota and they siad that the everything is different, but online, the parts go from 91-97. I need some parts but want to make sure they fit. If anyone can help please let me know. Thanks
i put an early 80 grille on my 97. took a lil cutting, but all in all it fits. doesnt follow the bottom trim lines properly, but its barely noticeable...behind an arb bar and 8" lights anyway. i reckon the corner markers and signals would fit too, but cant say 100%.
Tail lights and the front blinkers (or corners for that matter) would fit, no matter what year. (Chrome trim would be slightly different).
The grills are interchangeable as well, but does not utilize the same screw spots for holding them in place. But they will not fall off or anything!
If we're talking about the headlights and the grilles with the LX450, then there are more obvious differences/difficulties.
G'luck!
Since this thread seems to be almost completed in referrance to the OP's question, I'll pose a new one rather than starting a new thread. Sorry for the hijack.
Will the gauge cluster from from a 3FE work on a 1FZ?
My trip doesn't work and I'm wondering if I can replace it with this one. Or at least use the speedometer assembly as my trip is broken and I want it to work. :)
Thanks in advance!
Also, Does anyone know if the front differential from a 91 will fit a 96?
Thanks.
I think we need a "Will it interchange?" thread.
Things that will interchange:
Taillights
front blinkers
front corner markers
rear corner markers
Taillights
front blinkers
rear corner markers
I know what you mean. I just picked up a 96 and there are some things I want to replace with OEM parts but unsure what I can or can not used from a 91-97. It's hard to find parts for Landcruisers in AZ.
