Paint Code
Boise ID
1971 FJ55 Gray and White Anyone have the paint code for the gray? Thanks
My 71 55 has the original grey/white paint.I can look at the color code mounted on the truck,if someone can remind me where to look.Is it the plate on the door jam or inner fender.Ill look tomorrow
I looked at the data plates under hood and on drivers door jam no paint codes either place. I'd like to order some spray touch-up paint but need a code to order it .
Thanks
Still Looking for code
Bump for some help?
Hi guys I still need the code for FJ55 gray My pig is white and gray and I'm unable to find the code listed anywhere for 1971 Gray. Help please I've checked door jam, firewall, and fender plates no color codes listed.
Thanks for any help
My '76 has codes on the firewall plate. Why not post a picture of the firewall plate and maybe someone can read it or interpret it?
Thanks
Im pretty sure this has to be called gray or grey??? I know the green and its not green it's clearly grey/gray.
I'll post a picture of the firewall plate but as a little background I was a Toyota Factory service rep in the early 70s so i'm pretty familiar with the plates and data. But I'm willing to give it a whirl - As an old guy I've forgotten a lot more than I ever knew then and maybe somebody can crack the code.
Here's a picture of the pig if it will help plate pic will have to come tomorrow.
Thanks for the ideas though I'm needin some ideas.
In '71 I don't think that the paint color was listed on the tags. I know on my '71 I couldn't find it. Mine had been repainted twice, a solid white, and then a redish color, before I finally found the nebula green underneath. I would do some searching and see if you can find the base color underneath. I am not sure that grey was a color option in '71.
Ryan
Totally possible as my '67 FJ45LV doesn't even have a VIN plate, just the VIN number on the frame horn!!
Thanks guys! Still need code
No codes on the plates on firewall or door jam Over the weekend I scraped a small place and she's gray/grey down to the whiteish factory primer. She has the standard two tone color lines so I'm pretty sure she's factory grey/gray.
I've checked the paint charts here at a couple cruiser vendors and at a couple of paint sellers that will do factory colors for you.
My next step is to check with a body shop to see if they have any resources. Maybe they can give me something that's really close --- did Yugo have a gray color? :hhmm: Thanks for all the help guys.
Commercial message - Thanks Cool Stream of AZ Rex there (a mud member) helped me out and found someone that could rebuild my denso compressor for my factory/port installed AC unit. Thanks much Rex!!!
i have something in my notes about a code t450 gray used on pigs, but not sure...you might check and see if you can find a color chart with that to match to your rig
my 71 pig is the same color from the factory
just wanted to chime in.....I have a May 1971 FJ55....it is the same color from the factory......I've taken it down to bare steel in several locations to confirm this. I'm not going to repaint mine that color but would be interested in knowing what it is and what the code is.
.....not too Hijack here but, can someone confirm that the white portion of our pigs is Cygnus white for 1971?.....is it code T-12?....does that sound right? BTW-good looking rig!
Yes Cygnus white is #012.
Paint
My Pig is June 71 Production date. I've scraped a few places down to metal also. I guess they built a few gray (grey) and white vehicles but they never made any of the spec sheets I've been able to find. The 450 looks close so far. I'm locked to repaint the truck the same color because i spent some good money to already powdercoat the wheels to match the truck. Besides i like the color gray (grey) whatever the code is.
Thanks ----- yep the white is 12 it's available from Cruiser Corps I think as rattle can
