P/S options?
Santa Monica, CA
Website
www.elirubelphotography.com
Im sure that this topic has been covered before, but Im trying to figure out what the best way to address the power steering issue is. I'm running 35's (not sure if that makes much difference). Is saginaw my only option? I was looking at kits and most of them seemed to be in the $900 range. Is this what I should expect to pay to get set up with P/S, or are there more affordable options? Ive seen people mention somthing about hydro assist- what is this, and would it be aplicable to my situation? better price range?
Thanks for your help,
Eli
There are several options available.
This topic has been beaten to DEATH.
Copious use of the Search function will yield the info you desire.
PS
There is a guy around here that has a nearly comprehensive list of all the parts and part numbers for the GM Saginaw Power Steering conversion.
I'm in the process of getting all things needed for the mini-truck power steering conversion for my 40 now, romer has a great write up about it. search and you will find it.
Godd luck .. :beer:
Scout and FJ60 are other options similar to Saginaw. If you are running 35s, forget about mini-truck.
Ed
If you use a mini truck what are the biggest tires you should use... I see you have 33" do you find any problems with those and your mini truck set up?
I think 35" is max and that may be too much if you have a front locker or wheel it hard. Mine turns the 33s very nicely.
GL
Ed
alot of the price depends on what you can do yourself, example, shop around collect peices as you find them, did mine for way under 900 dollars.
The mini truck steering is a great set up, I have used it for many years. The only issue (aside from tires over 35") is that it does not eliminate all of the push-pull steering crap, and your tire WILL hit the relay rod. You can turn out the stops to avoid this, but you lose a good bit of turning radius.
I am on 38's now, and will be going fj60 when I get off my lazy ass.
