I did my timing belt/water pump replacement this weekend. I'm at 221K miles. The original one was done at 129K. The old belt looked fine when removed. Also replaced the fan pulley. Everything went according to plan. Started right up once I remembered to put the MAF sensor back in place. Runs fine. Sounds exactly like it did prior to the belt replacement. The issue I am having is that it appears the cooling system is not circulating correctly. I double checked the serpentine belt. Power steering, AC compressor and alternator are working fine. I cycled the front and rear heaters. They both appear to be working correctly.
Once the engine gets to operating temp, it will die and the key will not engage the starter again until the engine temp drops back down. Once it does, it will start and run just fine until it doesn't. I did not replace the thermostat because the parts store did not have the O-ring type gasket with the groove that goes around it. I removed the housing as one piece and did not disturb the current Tstat. Is there some kind of fail safe protection for the engine that will kill it once it overheats?
I'm stumped. If it had jumped timing, it would surely run rough or not at all after the engine cools back down.
Has anyone experienced anything similar? Would appreciate any insight.
2006 LX all stock except for 33" tall tires.
