Over Heating
Orlando, Fl
so i have a new water pump, new radiator, and new hoses, and its still running really really hot. anyone know where i can get a new thermostat housing? and what else could be the cause to run hot.
sidenote: my carb whistles, very high pitch and loud. any ideas?
Like you were heading towards, bad thermostat possibly. Have you tried Marksoffroad.net, Cruiseroutffiters, Cruiserdan, or lastly SOR for the housing?
i havent gotten to burp the air out of it, (live in florida, hard to find an angle) how steep does it need to be?
and how would i contact cruiserdan?
just mention the us rifle cal 30 m1, that will bring him around.
if you can wait that long just blasphemy above said item.
I would say you have a vac port leaking on your carb. If you spray some starter fluid around the unit and your idle increases you have a bad seal somewhere (ie cracked hose or intake gasket).
Did toy use a fan clutch on the sixer? I had a rover with a failed fan clutch and I replaced everything else until I found it. A pinhole in your thermostat (outer ring) will help with bleeding trapped air.
Have you checked the temp with another guage? Are you sure it isn't just a bad guage?
FWIW, I did it on a curb and it worked - bubbled up air. so, I think just as long as it is an upward angle for air to travel, you do no need like an actual hill.
Mine had a really loud whistle to it when I got it too. Couldn't find a vacuum leak anywhere. Finally found a post here that suggested that the carb might be overtightened. Took the bolts off and put them back on tightening them evenly and snug. Whistle hasn't been back since.
good news, i popped the bubble (in a way) i found a huge sandpile and went up onto it, almost vertical... and when i took off my cap, lost of steam came out, but not much water. (after i had filled it) so thats good, im gonna put some rad. fluid in it, and some water wetter to help.
next issue: wistleing carb... i loosened the screws on the top of the carb, but im wondering if the ones at the base could effect that also?
15 inch rims. no back spacing and like a -1 inch lift cause my springs are sagging (thinkin about getting add-a-leafs soon)
You are running lean, find that vacuum leak
yeah, theres a bit of rubbing when i hit hard because my springs are sagging, but not much besides that.
k, i plan on looking for a leak while i resetting the carb on the manifold
SandRider//Jonathan
