- Thread starter
- #121
Rusty Pig--thanks, those are from a 1984.
The cross member mount looks great, what year 60 is that from?
Back in Town and back to my project:
I got the thrust bearing and put it on and reassembled the TC. Then that night I started reviewing previous post and relized I didn't put on the 5th gear oiler. I e-mailed Cruiserdrew and asked if it was really needed..Affirmative.![]()
I really like to take things apart 2 or 3 times to make sure I know it backward and forward.
!!!!! DON'T FORGET TO PUT ON THE 5TH GEAR OILER WHEN REBUILDING THE TRANSFERCASE FOR A 5 SPEED !!!!!
So I had to wait for a new seal after I tore it down again.
The TC is all put back together again, except for one switch that has to be repaired and the vacume actuator for the 4wd, I'm going to wait until the tranny is in place so I don't inadvertantly break it off during the mounting process. Also, I put on the shifting fork and throw out bearing. Brake line repaired. Almost ready to put in.
I need to mount the flywheel and clutch.
I measured the differences in bellhousing to TC. The a440 from bellhousing to TC is 26 3/4, The H55 is 21 3/4. 5 1/2 inch difference.
I'm trying to get the tranny in this weekend.
Pictures are Oiler, Oiler in place on front of TC, and reassebled TC
So I'm thinking I'd get some 1/4" plate, form it into a "U" to basically cup the frame rail, weld the crossmember mounts on the sides of the "U" that'll be inboard of the truck's frame, then drill it so I can have two grade 8 bolts on the top of each frame rail literally pinching the plate onto the rail. The same way the RLMS 60 series sliders mount to the frame:
Anyone thing this will (or won't) work?
My gut reaction is: don't do it. If you can't get it welded, bolt it to frame, but, make sure you sleeve the frame or add a piece of steel that is the same width as the frame rail on both sides. A bolt with a large washer will compress the frame. You could call a mobile welder dude, get it all fitted up and have a truck show up to burn it in![]()
Also, make sure you have a factory service manual. Good Luck
Good call, Jim. I'll be ordering one soon if they can still be gotten from Toyota. Or at least seeing if I can get one somewhere.
Godwin's part # is for the reprinted manual from SOR. The fact that SOR is selling a reprint leads me to believe that the OE FSM is NLA. The 85-90 FJ6x,7x Body & Chassis manual has complete coverage of H55 and split case rebuilding, FWIW.
33124-36010-Oil Pipe (nipple)
Ex
