online manuals
* F A N T A S T I C *
Thanks a MILLION :beer: :beer: :beer: :beer:
Would it be okay if I added the ones I'm missing from those above to the downloads site too?
Feel free. The A442F FSM has traveled a bit, I got it from a second hand book seller in Australia.
Have just finished downloading the 2007 EPC :bounce:
The 2007_toyota_epc_install.zip is empty… so how do we install the disk??
Do we just load them in the old 2004 EPC??
Regards Christian
Just checked it from this end, (did a fresh download just incase), and it appears fine. Are you sure it's not just Windoze which is hiding the files? One is a DLL file, (no idea what that's for, but left it in there just incase), :D and the other file should be an iso image.
I believe that method should work too, though don't take that as gospel. :)
Owner's Manual?
Where can I find an owner's manual for th HDJ81 / 1HD-FT?
the UK was a giveaway when you used the word "whilst"
Starting in slight babble mode first, it's amazing how much attention one pays to that word once it's brought to their attention. :D Seems there are only a few over our way who use it in general too. :D
Just wanting to ask, btw, if it would be preferable for me to add the RM numbers to the download descriptions for the Toyota manuals, where applicable? Would it possibly make finding the manual one is after any easier?
Also, any opinions on the torrent system? Has anyone downloaded via that method? If so, does everything work as expected, and does it seem to be coping/working better than the ftp system?
I used torrent to get the EPC and it seemed to work well. The FSM's often refer to other FSM's by number so that could be useful.
I noticed the other day we've got a FSM download service from Toyota in Europe similar to that mentioned elsewhere on mud for the USA.
http://techdoc.toyota-europe.com
I would like to take the opportunity to thank you for an EXCELLENT PDF conversion. Most of the text IS text instead of simply pictures like one can see in other 'photocopy' manuals, which contributes to its very compact small download size. Nevertheless, the pictures are very clear. Kudos on the OCR and for a job VERY WELL DONE!!! :cheers:
Cheers. That's good to hear. :) I was beginning to become a bit paranoid regarding whether it was working okay or not. :D
I've updated them now with any manual PN's I could find, so it should make life a little easier. :)
I've also added a reference id under each download too, so if anyone does notice a description that's incorrect, or knows the correct PN that isn't already mentioned for a specific manual, just let me know the ref id for that download and I'll get it revised/updated. :)
Plus, I've added a direct link to the category for each manual listed when you do a search, so that you can go to the respective category for each manual displayed in the results. That was a complete bugbear of mine, the lack of a category link, so I finally decided to get it sorted. Should be a bit less arsey to navigate now, hopefully. :D
Will do. :) I occasionally have a run of trying to find missing and/or new stuff, so they'll get scoured for again when I'm having one of those sessions. :D
Matt,
Snailtrail and I are working on getting the 14B and 15B FSM scanned to PDF. (His manuals, my scanning) The plan is that once scanned I'll send you a copy of the file for the library. Any suggestions on scanning resolution that seems best. Cheers.
Matt,
Cheers. You're a star. :) If I remember correctly, (bearing in mind that it has been an awfully long time since I last did any scanning), I believe the best resolution for quality/size ratio is around 300 to 600 dpi. Anything above that tends to lead to bloated filesizes for little, if any, visible improvement. I'll double check and see what info I can dig out though, just to be on the safe side. Thanks again. :)
Any of you European guys have access to a BJ74 manual? I'd even settle for just the wiring diagram. There might be a Japanese version as well that would do in a pinch.
Bearing in mind that I'm definitely no expert where LC's are concerned, :D from what I can gather from this thread:
https://forum.ih8mud.com/70-series-tech/26405-bj74-repair-manuals.html
the manuals you need are already up there, (exempting the RM132E manual). I may be completely incorrect though. :D
I got one of those! I'll try to scan it next week when I get back to the office.
Cheers. :) :) :)
Dug this link out. The top section of this page, (ignoring the LaTex stuff, that's just a conversion software), seems to have some useful suggestions. scan-latex-pdf-HOWTO.txt.html
[offtopic moment]: Anyone know what's happening with the Birfield site? It's still showing no signs of life over there, from what I can tell.
Yeah, the 84-90 chassis manual is missing the BJ74 info. It has BJ70 info and that mostly will get you by but I'm interested in the engine control systems that are not in the 13BT manual. Specifically I want to know what the circuitry that controls the VSV that closes the intake shutter looks like. There is some voodoo that shuts down the engine at 4000 RPM under light boost or as low as 3000RPM under heavy boost. This can be troubling if you are half way through a deep mudhole or freeway onramp. If I disconnect the vacuum hose to the shutter, it will happily do 4150RPM at 20 lbs of boost. I'd like to be able to do this and shut off the engine with the key.
