One Wheel Drive in Low Range???
Athol, MA
This past weekend I burried my 1997 in a very deep mud hole while exploring the back woods of Maine. While in Low Range only my front drivers side tire was spinning. This tire was not burried in the mud like the other three. My rear tires with an Aussie Locker and 4.88's weren't even turning. The tires are 40" Michelin XL's and they were 3/4s under the mud. With the center diff. locked while in Low Range I assumed no splitting of torque would occur. Did I need to spin the front tire longer to engage the VC to the rear wheels? One wheel drive in this situation had me pulling winch line when I probably would have gotten through if the rear tires were spinning. I'm confused..... Please help......
Yeah, same thing happened to me (kinda).
I was going up a steep hill where the right front tire would dip down into a DEEP rut and spin with no traction, but the other wheels didn't do anything.
I have an unlocked truck, with NO aftermarket lockers. It was definately in low range but I couldn't understand why 1 of the rear wheels wouldn't move to help push me forward.
I have not done the pin 7 mod. The truck was in low range and the ABS light was on. Maybe I need to call Christo and order a center diff. lock switch and do the mod. I thought that once in low range the VC of the transfer case was locked. If the front tire was spinning it only makes sense to me that the rear tires should spin as well. Any other ideas?
The center diff lock light is on as well as the ABS light when shifted into low. Additionally, the truck is in low range. Could the suction of the mud overcome the torque converter? I just may anchor it to a tree and see what happens when I put it in 4 low.
Sounds like the issue is front to rear split for sure. Sounds like no front locker so the spinning wheel sounds normal...
You have CDL issues. I have been in similar positions and had no issues.
The VC is out of the equation when the CDL is locked, at least if the CDL is working. Sounds like the CDL is not working correctly.
Hmm...
I didn't think that the Light would come on solid unless the CDL was physically locked up....
Hmm...
your right, it should only light when it is phisically locked
see page 74
http://webpages.charter.net/raventai/HF2AV TRANSFER.pdf
it shows the relationship between the center diff lock shift fork and the center diff lock indicator switch,
there is a diagram of the L4 switch on page 71 witch is similar in construction,
I'll give it a shot once I get home. 4 Low and turn in a tight circle. Call me old school but on a mostly off-road truck I prefer a transfer case with no electronics to get in the way. Gear to gear, when your in low you know it.
Strapped her to a tree, put in low and sure enough both rear tires and one front tire spun. I still can't figure out why the rears didn't spin while stuck...
