Lots of stuff getting completed and off my plate finally. But lots of hiccups along the way. The York OBA Kits are in shipping purgatory, the SB50 cables are waiting on sleeving, the D-Pillar is waiting on time from machine shop to bust me out another proto, all lockboxes have left the building, etc etc. So I found myself with larger pockets of extra time. Knowing the York Kits were close to being done and shipped out I knew I need to get going on the rest of the kits. So I've been ordering just tons and tons of different components and pieces and fittings and stuff to make up the kits the way I REALLY think most could benefit.
BUT...I'm no expert. So now is the time for some feedback and to let you all know where this currently is. After installing three other OBA setups I've learned a ton and I am looking to not repeat those and other mistakes so that the kits I am finally able to offer will be nearly as plug and play as I can possibly get it without any worry about the effectiveness.
There are at least two things I wanted to go over and get some feedback on. One is the air tank and the other is the air manifold. First some background...
OBA (On Board Air) is having on demand air ready for airing up tires mainly but can be repurposed for air tools and blowing up air mattresses, etc. The source for the air in the OBA can be from CO2, electric compressors or from belt driven compressors. The 1FZ has the luck of having a York 210 that can be mounted onto the PS of the motor that is made by companies such as...well...mine
Since the air can come from at least three sources, it now needs to be regulated and/or stored when needed. Most electric compressors are on-demand pumps with no air tank but built in regulator. Some larger units have tanks as part of the unit. What I am looking to make available is an air storage system and an air manifold setup that doesn't involve sourcing parts nor trying to figure out what, where, when, how and why.
Here you can see an atypical OBA schematic and is slightly overkill, kinda like our Cruisers:
My first bracket kit will be to mount the Viair (or similar) 2.5gallon air tank UNDER the truck where the spare tire used to be. Still have the spare there? Have dual gas tanks? Don't worry, other options are in the works. But this is going to be mounted under the truck using existing holes found in the chassis. This is a zoom-in of the air tank and a schematic view of its general location.
Here is a better illustration showing what it will actually look like as an installed piece with the components all hooked in:
Here is my cardboard mockup before going into steel before final prototyping:
