how do you fit a 3/4 drive socket onto the DS top shock mount?? A std. 1/2" wobble and socket won't fit for me. I think christo has a 1/2" drive socket with a built in wobble for that job.
spartan said:Shocks - take the top of first. Hit it quick with a 3/4 " impact and long socket. It will come right off. Same for install. Impact will run the nut down before it has a chance to spin. Have someone just hand hold the piston shaft if needed.
spartan said:Shocks - take the top off first. Hit it quick with a 3/4 " impact and a long socket. It will come right off. Same for install. Impact will run the nut down before it has a chance to spin. Have someone just hand hold the piston shaft if needed.
Nay said:Ken - your regular OME shocks are a bit short at this point. But if you plan to keep 33's...L's probably won't help you much. Why have less up travel and not have the bigger tires to go with it? If you are going up in tire size, you should absolutely get new shocks.
Nay
nakman said:just measured 22 5/8", looks like a 3" lift- Also 38" to the floor.. 850J, 33" Trxus, ARB, M12, Dual batts, snackster cooker. (863 rear)
