OME Comp Springs Installed
Are the slee arms the only drivetrain mods you've made? Have you done anything about panhard bars or swaybars or anything like that? I'm trying to decide what I need to do, it's getting close to time for new tires and some 37s would be schweet.
Slee arms, adjustable panhards, adjustable rear uppers, front DC shaft, and sway bar drop brackets. There is room for 37s but as Eric mentioned, that is a big jump and would cost more than just tires. Yes I get some vibrations, I have not taken the time to get them sorted out. They were there before the spring swap, I have just been lazy. (Lazy=Spending the summer springing over my 40, which is just about done)
no that was serious, definitely interested in seeing how these turn out. I'd personally rather not run the spacers, And we appear to be at the same height, which is pretty nice.
looks great sir!
thanks for the report!!! :cheers:
Meet me in Moab next month and I will let you take it for a spin.
good info!
I think once you get above the ~3.5" range, you are opening up a can-o-worms in terms of mods. It's just the geometry issues with 80's radius/link suspensions.
You'll have to do the panhards...
You'll have to do some sort of higher caster/angle mods
Possibly upper control arms
Possibly CV Driveshaft
And if you are thinking 37's DEFINITELY gears...35's still need them but I can't imagine 37's and 4.10s...Currently we only have a few options for caster outside of making your own setup.
EDIT>>>I doubt 5" is enough for the arm flip without serious bumpstopping. I'm at 5 and it still looks a little close.
I think we get spoiled when we can throw a 2.5" lift on, 33's, maybe 315's for ~$750ish and go everywhere. It's that next 2-3" that creates a whole slew of issues that need dealt with.
...I think we get spoiled when we can throw a 2.5" lift on, 33's, maybe 315's for ~$750ish and go everywhere. It's that next 2-3" that creates a whole slew of issues that need dealt with....
Soooo true. I always tease with customers that a 3.5" lift is ~$750 (J-series) you basically start to pay $1000+ per inch thereafter :D
Dang I want these up front... I'm happy with the J's in the rear, but with Slee front bumper, heavy Warn 8274 and a 3FE, all that weight has made my front J's with 2" spacers sag pretty bad.
Am I a good candidate? I was thinking of the Slee front 4" springs but was still thinking I'd need a spacer. I also like cheap things and at $129 ea. that sucks.
OT- while on the trail, I run true Swamper 36's with stock gearing and a 3FE... and it works!
Give Kurt a call, if you are really nice to him the springs will be cheaper than $129 (more like in the $85-90 range)
Check out the picture in the mountains I posted next to the other 80. That is DMC's. Dave's cruiser is setup with J's front and rear with 1.5" spacers up front. He has an ARB bumper with a Ramsey 9500 winch. You can see that I am a little taller. You know your rig better than me but the Comp 4" springs might be the ticket up front to match the rear Js. I was running Js with 2.5" spacers up front and the 5" springs sit slightly higher. Are you running any spacers in the rear?
No spacers in the rear and happy with it. I need about an additional inch in the front... My front sits almost equal or barely higher to a friends 80 and he runs the j's with 1" spacer up front with an ARB and no winch.
I think I just might have the heaviest combo up front.
Too tempting? Did I mention they ride great?
I know, and actually i am glad you posted. I would just worry that perhaps with costs and overhead, curt couldn't pass that price to everyone. Then some may get their panties (mostly the LX folks) in a wad when he couldn't sell them at that price.
I think these are the ticket for me! ;)
Do you think the 4" rear 5" front is the way to go? I have a TJM bumper and Spare tire carrier on the back. But OME rears are typically quite a bit taller than the front, tons o stinkbug...which I don't want.
This is exactly how I am setup. I went for the 4" in the rear because I did not want to stink bug. I have rear bumber parts in my garage (thanks wildyoats) but have not yet assembled and installed. My 80 sits level now. Hopefully the bumper does not cause the ass end to swag. I figure with the heavier spring rate I should be OK.
I should have mentioned that I am local to Kurt and was able to get my order in when he already had a palet headed his way, that meant no shipping for me. The price I posted was based on a post by Kurt earlier in this thread, "They retail at $129.01 each versus $96.24 for other OME springs. Of course I've seen them sell for ~$85" You are correct though, prices are subject to change. Better order soon.
hmm, so I have the really heavy setup...slee front with an added hoop, 12k winch, and about 100 pounds of rubber sprayed on it. I am thinking 5" front and rear?
I am heavy as all get out across the board.
Dan, did you see how the front end of my wagon, popped back up everytime I got out of it? I'm kinda rotund.
