OME CC Bushing Quote
New York, New York (LI)
I was just quoted $480 to have my control arms dropped and have the CC bushing installed. Thats way out of the ball park right?
Seems expensive to me. If you have two wrenches, you could always remove the arms your self, to save a little $$$. If you are confident in the instructions, you could probably just have anyone with a press push out the old bushings and press in the new ones.
Was he wearing a mask and a 6-shooter?
I took mine to a local spring shop and they dropped the arms, pressed in the bushings, and put the arms back on for $70 total. I think this is a bargain, but they told me it didn't take long and wasn't difficult.
Up here (B.C. Canada) I've had several quotes all around the same, around $100 CDN + taxes. So $480 US seems - I'd better not use the word outrageous again, but very, very high. Doesn't Slee charge around $600 to do a whole EMU system?
I think the guy just doesn't wanna do the work which is fine b/c if he doesn't wanna do it then I don't want him doing it. CDan, he had a Regan mask on and his buddy had a Nixon mask
We charge $170 if the truck is dropped off, and $85 if the arms are brought in. Suspension with caster bushings and steering dampner is $382.50. These are at 2006 rated (just in case someone comes back in 2010 and wants a price match :D)
I paid $211 including tax including the alignment.
This was based off the quote the guy gave me, he had never done one before, and I could tell he thought it would be difficult. Best alignment shop in my area, 4Wheel shop recommended them.
He made a big deal of getting my truck there before they opened, and needing it all day.
They called at 10 am and it was done.
I drove it for 2 months or so post lift without it, and am really pleased with the results. I loved the "heavy feel" of the steering pre-lift, and got about 80% of that back after the CC busing install.
$380! :mad:
That was at a shop I trusted too. I just dropped off the truck and said "do it", after having good experience there in the past.
That was the last time they worked on my truck.
Find a local machine shop that has a press. Ask around local auto repair shops and find out who they use. Pull the arms off, walk in with the bushings, arms, and Rick's template and explain exactly how they should be done. I paid $20/per press, $80 total.
The R&R of the arms is not difficult and can be done in a driveway. Air tools make everything better.
12 ton is not enough of a press, the place that did mine said it took about 45 tons:eek: to get mine to break free!!!
It probably depends on where the rig came from? Rust buckets require more power, clean trucks less. I have pushed many sets out of AZ rigs with my 12 ton, it takes all it has, but gets the job done.
That's kinda nuts, a 12ton press runs around $100. Just as well to buy a press and do it yourself.
X2. Got mine at harbor freight for $100 on sale. I got the job done and got a tool for the cost of someone else doing the job.
I had to carefully cut mine out with a sawzall. Two cuts close together and a punch and hammer to take the small section out. Then it just fell out with a few love taps.
i paid 400 for the entire lift and cc
