What kind of boost can a stock 606 maintain without heavier valve springs?
I might be talking or my butt, but wouldn't that be an rpm issue?
The glorious sound at 7k rpm is reason enough. LolI think you are correct. It's an rpm issue. But Like @DirtSniffer said, I thought I had heard with higher boost they can float with the stock springs. Not 100% on that though...
backpressure is a bigger issue then boost. 40 psi on a 16cm he400 is fine but 25 psi on a he221 6cm will float the valves. Thats why Mercedes decided only make the exhaust valve springs stiffer on the om648. of course RPM is also a factor, if you have a back-pressure gauge it would probably help tuning in that compound setup and you might be able to make quite high boost without floating.What kind of boost can a stock 606 maintain without heavier valve springs?
