I've done that on other cars in the past, but as badly as mine is cracked, I'd be afraid to try it.Old junkyard trick........Take the steering wheel to column nut off, lock washer and horn contacts. Sit in the drivers seat and give the wheel a tug towards you, it just might come off. Children please do not try this without adult supervision. John
I did try that, no go so far.Another steering wheel trick, back nut off until it’s flush with the shaft, and tap lightly with a hammer while pulling the wheel towards you, the idea is to (shock the splines). Works most of the time! Rig is looking great!
Pro-tip: thread the nut back on the shaft a few turns so the wheel doesn’t hit you in the face when it comes offOld junkyard trick........Take the steering wheel to column nut off, lock washer and horn contacts. Sit in the drivers seat and give the wheel a tug towards you, it just might come off. Children please do not try this without adult supervision. John
I have a good, blasted step and tread trim, and a passenger tread trim. Maybe with @whitey45 we can come up with a set. John
Inviting you both to a conversation! Excited!Looks like all the stars are lined up!!
I have a pass side!! Needs a bit of straightening but good usable piece!
Got the steering wheel off today, the cancelling pin is there. But for the life of me, looking at the turn signal arm, I can not see how the pin can trip anything. Am I missing some parts in there?You might check to see if your turn signal cancelling pin is still in your steering wheels hub?
Oh, under the dash? I’ll have to take a look.I think it trips at the other end of the shaft?
NopeI think it trips at the other end of the shaft?
