Old Man Emu Suspension Help
"the whale's vagina", CA
FRONT = OME851 | 2.5" | 0-110 lbs
REAR = OME863J | 3.5" |200-440 lbs
I have the option to purchase the above old man emu kit for a 96 landcruiser. Some questions:
** I know that I will need to run 1 inch spacers in the front to level things out? are spacers necessary in the rear? OR do you want to have equal lift all around? I know on my fj40 I had to lift the rear a bit more than the front to compensate for gear.
** I am looking to setup the fj80 to be comfortable on the freeway, we are planning many family camping trips, etc. This will be an all around vehicle BUT I want the option to be able to take it on the rubithon and some other tougher trails (not the hammers), I am ok with bypasses, etc. I have factory lockers and plan to have bumpers and sliders. Does this kit afford enough of a lift for these trucks to run succesfuly through trails like the rubithon? I have run the rubi 2x but that was in my fj40 and it is a completely different beast, I had one rear locker, 3 inches of lift and 33's at the time many years ago. It was messy but I got through. I plan to run a winch on the 80 to drag my ass through if needed.
** Does this lift afford enough carrying capacity for a child, a big dog and a bunch of gear? I would think I would end up with at least 440 pounds of gear in the rear with the roof rack, rear bumper/ladder, fridge, dog, gear, spares. Does OME make other versions with a higher carrying capacity that may suit my needs better?
** I want to run 35 inch mud terrain tires, is this enough lift to do so? I plan to nix the fenders and do the linex thing, anyone have pics of their trucks with 35's and this type lift? that would be much appreciated.
thanks for the help, just trying to decide whether I will go this route or the slee off road route (more $$).
Noah
From past reading - NorcalDoug has ran the Rubicon on several occasions on OME Heavies 850/863 2.5'' lift with 35s (no flares) and no regearing. But then from pics his underside doesnt seem so pristine.
Noah,
I am running the 850/863 combo and I love it. It is a little rough unloaded, but once you put a few hundred pounds of stuff in the back, it is a dream to drive.
You may want to try this combo (850/863 non-J). I think with the setup you listed it would be very stinkbug. I'm not so sure those springs compliment each other. I usually see people running the 850J/863J and add a spacer in the front to level it out. But then you start to get into that height where you have to worry about serious caster correction, DC driveshafts, adjustable panhards, etc. My combo gives me a couple of inches of lift, but remains very drivable. Very happy with it. Not sure if you can run 35s without rubbing though...
This is going to make for big time stink bug. On a stock weight rig, the 851's net ~2.5" of lift, ~22" hub center to flare. The 863J's net ~5", ~25" hub center to flare.
The Aussie kits are setup for lots of rear load bias, the way most Americans roll having a slightly taller spring in the front most times makes for a more level rig. Like a J front - heavy rear for ~3.5" lift, heavy front - med rear for ~2.5" lift, etc.
With the OME spring rate you can loosely figure ~500lb over an axle equals ~1" of compression. So if you plan to have extra constant weight on one end, buy springs to match.
Here is a pic of mine with med 851 front and heavy 863 rear, your setup would be +1" higher in the rear.
I have fitted this exact set up a couple of months back. I find that when loaded with gear its great. Unloaded I feel its too 'bouncy'. I think I should have gone for lighter duty rear springs - as the truck is not loaded that often. Having said that, I have a monster run down through France, The Pyrenees, Spain and Morocco next summer ..........
I run 33's.
OME offer at least 4 rates of spring for the rear - but I think there may be 5
860, 863, 864 and 868's
http://www.tbruk.com/index.html?lang=en-uk&target=front.html
And unloaded we have serious stink bug ...........
Here's a list of all the OME springs (per Slee's website):
Slee - Springs
If you are running a bumper and winch on front then I would think that you would want to go with the 850 springs in front (for 2.5" of lift). You then have a couple of choices for the rear. I would keep the lift heights matched, if it were me. It seems like 850/863 would be the way for you to go but what do I know??
I agree w/ above on that setup giving some serious stinkbug. Id run like tools said, js/heavies or heavies/mediums but then again i prefer the level stance. Make sure to get the L shock if you do end up going w/ the J spring.
heres a pic of the J's up front, Mediums in the rear and linex, armor,no flares, etc on true 35's
Noah
Your answer will be determined by whether or not you actually want to buy what you really need.
... Make sure to get the L shock if you do end up going w/ the J spring. ...
If you plan on wheeling in the rocks, with 315's that require bump stop extension, I would run L shocks on the rear with any spring.
Theres more that that over here now. We do not get the "J" springs anymore, but we do get the Compation springs.
Anyway I run 35" tyres with 850s + 25mm packer on the front and 868s on the rear, but with the Diesel and all the kit in the rear it rides fine. But with no load it would be a bit hard.
Paul
That's one of the nice things about the OME setup, plenty to choose from to tune the setup for your needs and a good resale market, making changing springs relatively $$ painless. IIRC we have 7 front spring and 8 rear spring options.
concrete jungle, that is a nice truck and that is what I was looking for as far as pics, are you happy with the lift? what did you have to do other than the standard J lift kit that OME sells? I believe the kit comes with caster correction included. Do the OME J 3.5-4 inch lift kits require any other mods other than simply swapping in the kit? I have heard of the need to alter sway bars, etc?
FWIW, I installed heavies/heavies with a 25mm packer in the front. With only an extra battery for weight in the front, it sat about 1 1/2" higher in the rear. I skipped the OME bushings and went to Landtank's plates for castor correction and had a Taco driveshaft converted for the front. First off, Rick's plates are top notch and stupid simple in their engineering. They not only correct the castor, but also give you about another .75" in lift since they correct the axle angle / spring angle. Basically they make the coil sit straight in the axle. As others have mentioned on here, the ride with OME vs. stock is night and day better. As for swaybar extensions, I used 2" square tubing for the fronts and 2" c-channel to make new longer rears.
So far I have done some pretty tough trails and have been impressed with the set up. I still plan to extend my panhard rods, but that is more for appearance than function.
I used slee blue bushings for CC. Had plates at first and it was too much, and the Yellow bushings that come with the kit were not enough. It drives great right now. I used Landtank's template to install the bushings which i think does two things, 1. makes installation idiot-proof and 2. rotates the axle on it's axis, allowing for proper alignment. I have no grrr. I do have a DC front drive shaft sitting on the shelf because when i had slee's plates i needed it. Now that the plates are off, i don't need the DC shaft.
No issues with the tie rod, now. There were issues with slee's plates. Let me note that i'm not knocking slee's caster plates. I had one of his first versions and also really didn't have enough lift to run them, so i over corrected. This caused the tie rod to hit on the control arms.
For the record, i'm not happy with the medium springs unless i'm completely unloaded. When i load it up for a trip it feels like a marshmellow in the back. It's too soft. I should have gotten the heavies or the j springs IMHO for the rear. Before i had a rear bumper and sliders, the medium rear springs were perfect. But with the addition of the bumper and then add weight for a trip and it's too much. BUT, the funny thing is it still sits pretty flat, just too soft.
I really think the medium kit is perfect for anyone who wants to run larger tire size, wheel the rig and have sliders. Start adding bumpers, winches, weekend worth of kids/gear/food ect.. and you are no longer in their useful spectrum.
