94 FJ80, stock.
Last year when changing my oil I decided to use the larger size Bosch oil filter (because bigger is better
). After that oil change the engine would initially idle much higher than it had previously then slow down to normal as it warmed up. I had also changed oil brands to Formula Shell (it was on sale at Costco) so I was unsure which was causing the higher idle. Next oil change I used a large Mobile 1 filter with Formula Shell which produced the same high idle speed. Today, I changed the oil with a standard Toyota filter and Formula Shell oil and the idle speed dropped significantly. With the large oil filters the initial idle speed was roughly 1800RPM, after changing to the small Toyota filter it only went to a little over 1000RPM. Admittedly the engine was warm after the change but with the large filter it would get close to 1800 (briefly) even when warm.
I know the 1FZ has a tendency to idle fast, especially when cold, but I've never heard about an oil filter influencing idle speed. The cruiser drives perfectly fine with both filters so I'm not concerned, just curious if anyone else has experienced something similar and/or can explain the cause of this.
