Media Official 35" and under!! Post pictures!!
Photo/Video/Audio threads
...315s duratrac now
Crap now I need more lift!
20160407_094218_hdr-jpg.1237880
@Ozpall What suspension setup are you running? Stock?
35s no lift!
Any bump in the road will rub!
Looks good! Out of curiosity, where do you rub? I believe I'm running the OME stock height kit with 315, no flares and I don't rub at all. Do you think that your rig is sagging at all, or do you think it's the flares that make the difference?
EDIT: Looking at the pictures on here... it seems like I have some lift... 21.5" hub to fender in front. Any OME stock height guys care to weigh in? Heres my rig:
I had a bunch of equipment for my 18 wheeler in the back. Maybe 200 to 300 lbs. So it would rub the metal behind the flare. Just the inside lip of the fender arch. And my suspension in that picture was the original springs, so they probably sag.
So, when you rub, it hits the metal body... not the flare?
Yup, it rubbed some of the paint
Does it rub in the front or the rear? I haven't removed my sway bar yet so I might see some rubbing in the front when I do.
Thanks for the info.
Found a picture with my rear tire stuffed. It didn't rub but I'm getting curious why my tires don't rub when other people's seem to.
Wierd! My axle must be spaced a little different than you. Thanks for the info and your rig looks awesome with those MTRs on it.
Most rub on the mud flap and the inside wall of the wheel well. My guess is you probably get a light rubbing on the wall of the wheel well but since there's no mud flaps you're not getting that.
Also, your Duratracs need to be replaced with a real tire. :) Besides they look a bit worn anyway.
Good to know on the rubbing. I need to install my LCP sway bar disconnects and see how that affects everything too.
... And I was patiently waiting for you to comment on my Duratracs, haha!
