Yes, though it can take a minute for the oil to get up to the top...if the engine is cranked with the starter would that also push oil up through the oil passages?
thanks, figured it would but wanted to check. I was thinking of one more option to check for oil flow here.Yes, though it can take a minute for the oil to get up to the top...
It's good practice to run the starter motor without starting the engine on a motor that's sat for a while.I was thinking of one more option to check for oil flow here.
Is that an F head gasket then?Pretty sure I have a ‘74 head gasket on the shelf.![]()
Well, can’t say for sure. If we could see the WHOLE gasket, we’d know if it was just installed backwards (teardrop between 2&3) or an F gasket (no teardrop)Is that an F head gasket then?
I would be concerned if you could blow through the filter ‘out’, as those are the passages to the bearings, and they should be tight, so the oil goes where it needs to go. IOW, if it’s easy, the bearings are failing.I'm curious, would it damage anything if I left the oil filter off and blew compressed air backwards from the port on the block?
I'll check this next. Thank you.Could the blockage be just in the filter housing? That seems like an easy one to check off the list. Good to know the pump works.
You're working through the problem.. it will come together eventually.I'll check this next. Thank you.
I ran the drill at a little more than half speed, turning the oil pump. No oil flow through the block and I felt and could hear something pressure back up. When I hooked my air chuck up to the top port I could blow air through and heard air flow, but I could not get anything blowing backwards from this port back toward the filter.Uh oh. How do you know it's not pumping oil and can you shoot air back the other way?
