Thanks for the part numbers... Will order these when the running boards unexpectedly fall off
Figured I would share this... link should work for '99 LC's (I just stumbled upon the site while looking to order the front mud flaps and everything to install) hope it helps!
http://www.toyotaonlineparts.com/pa.../base/4-7l-v8-gas/body-hardware/exterior-trim
Welcome and thanks for the link! You'll find this forum is the best bet for anything Cruiser related.
Oh nathan.... no you didn't. hahaha
Here are the part numbers for my '07 LX 470. The flaps and clips are different part numbers. Are they actually different from Toyota parts I have no clue.
Drivers flap (1): 76622 - 60070
Passenger flap (1): 76621 - 60080
Drivers Bracket (1): 76642 - 60020
Passenger bracket (1): 76641 - 60020
Bolts (6): 90119 - 06779
Screws (2): 90159 - 60576
Clips (2): 90467-10187
thanks for all the info. got all parts at toyotapartsdeal.com for $100.75.
Hey guys, I’m having fitment issues. Are you guys drilling new holes for these?
Front mudguard install right? They should line up with all existing holes and the additional bracket placement behind the front tires.Mine is a 99 LX. I went off of the LX part numbers provided above.
I see your from the Black Hills as well! What sliders are you using in the pic, and did they require trimming the front mud guard?
Agreed, I got burned on a LC cruiser roof rack cover part once, so important to know the LX 470 part numbers. Thanks for all the research guys!All the LX guys, what part numbers are you using?? @slowprogress, did you figure out what the issue was with your set?
