OEM Front heater install
Leesburg, VA
Did a search and no luck..... looking for a nice picture diagram to help me install this OEM heater... Inside seems to be no problem... A little confused about the heater valve placement....hoses....etc.....
thanks....
Heater valve attaches above the hole for the water tubes to enter the cabin.....
Hose from the top of the valve attaches to the cylinder head water port on the driver side rear on a Toyota six...
Other hose is routed to the tube on the lifter cover housing studs, behind the distributor..
:beer:
See if this might help. Ooops just realized you have a 1978 FJ. Diagram is for a 69-73.
BD, I have a 78' intact what are you trying to figure out specifically, maybe I can look at mine and help you out. Post a few pics of what you have and what you don't know.
Ok.....here is a pick of my firewall.....can someone show me where the hoses go through and where the valve mounts.. If someone can snap a shot of their mounting that would help the best...
I'll try and snap a pic today of the heater valve shown on the firewall, is that the only pic you need?
Thank god its a grommet.....
F-junker......that would be great....and another of how the hoses connect to the radiator.... Got all the parts....just need to to see it...
Oh.....and one of inside.....if you have a chance.
Thanks...
I've got the camera on the charger sorry I didn't snap them today. I did remove a plate today inside the cab to better show the hookups. the hoses/pipes extend from the heater inside and split for the rear heater hookups, the inlet and return pipes run through that grommet thru the firewall, I can't remember off the top of my head how the heater valve is plumbed but you will see it tomorrow as I will snap a few pics inside the cab and under the hood before I go riding, I'm headed to skyline drive for a scrap on some twisty turns. I catch up with you then.
Been searching for abit and found many pics.....but I still need the one of where the upper hose connects to the head...on the drivers side of the valve cover.
I also realized I dont have that heater pipe thats behind the distrib...I guess I can run straight hose...
Here are two more pics...... I think the black pipe goes into the block/head.....but whats the extra hole for?
Second....I attached a pick of my block labled A and B....which one does the top hose from the valve go? I think its the one next to the water temp sending unit?
I'm headed over to my garage now, I will have some pics for you today. If I'm not mistaken the hose in question connects to the head. The black angular metal peice above is that the fitting for your head? I ask because there are two outlets on it. As far as the hard line behind the disty you can run heater hose and route it any way you chose. I have an extra one if you want it you can have it for free, but shipping to you might be more than is't worth.
I believe that the labels shown A and B are fittings for temperature sending units. The outlet on my head is the rearmost of the head. I will take a picture of my head fitting and it's repesective location as well. Hang in there I'm on it, please be patient and I'll help you through this one.
Thanks F-junker..... not rushing ya...haha.... I was just outside and figured I'd take some more pics.. I'm heading to the Lake today so wont be back until 6 pm tonight....
Yea the pipe is confusing me because it has two outlets..... I'm sure its normal pipe thread so I can go to TrueValue and fix something up...
I'm in DC all the time.....will have to give you a shout.....
Hope you can see what you need to see....
GL
Ed
billdance said:
Awesome...... I see it goes behind the temp sensor......
Anyone know if the fan switch is 2 speed?
Mine's a '78 and the switch is two-speed.
ETA, when the knob is pulled out all the way out for the high speed, it also kicks on the rear heater.
You should have a resistor on the fan motor. Like Folsom said, the first detent is low and the wire goes to the resistor. High bypasses the resistor and gives the fan motor a full 12V as wll as powers up the rear heater. I've seen some of those that were two speed, too.
GL
Ed
If you are needing any heater parts and or blower parts, I do have some that might work.
Best,
Shane
No, just a flush-out fitting.
Ed
