OEM Front heater install
Since I cant plug the fan motor into the wireharness.....since my FJ is from SA and had no heat...... Anyone know what of the 3 wires coming out of the fan motor is pos....neg....etc.... It does have the resistor... See my first photo above...
Bill, I saw those pics last night and didn't put mine up. Let me see if I can get them off to you. I think you will see in the above pic the heater valve attaches to the firewall belowthe brakelines and above the hole in the firewall, your pic shows several zinc screws (nice BTW), that's where that baby should go, the hose on top of the valve goes to the water outlet on top of the head ( towards the rear). look on top of the head in the pic above, and follow it to the heater valve, can you see it? It is slightly covered by another hose.
The bottom water hose is the outlet I believe, this is the one that runs to the front of the truck into the fitting between the bottom radiator hose and the water pump.
I just found my web file and will put those pics up. The pics above are better than mine frankly. I hope this helps. Keep in mind the picture on the inside of the truck shows a hose loop going down from fitting to one to another. This is my crappy method of blocking off the rear heater until I make new pipes for the rear heater unit. If you don't want rear heat you could delete those fittings altogether and run your lines to the heater up front. Let me know if you need anymore pics or can't figure this thing out.
Are you in DC on business or family? give me a heads up a week or two before you come out next time. Maybe my Junker will be road worthy and we can take it out for a ride on the trail or just have a few cold ones. Take care and good luck!
