Oddball brake booster replacement issue
40Flipper
Master of Nothing
Mt. Millis
Website
www.rinnadvisors.com
I have a LHD 1969 FJ40 which already has a front disc conversion. The existing booster is BRAKE BOOSTER,SERVO 44610-60400, TOYOTA LAND CRUISER BJ60, HJ60..RHD. Yes, a diesel 60 series Right hand drive booster somehow ended up in this 40.
The issue is that my 1969 has the 4 holes drilled in the firewall (instead of 3 so no adapter needed) and this booster fits with the ribs. I bought a minitruck booster to replace but the threaded rod connecting to the pedal is way too long. I need the rod to be threaded all the way down to the rubber boot for it to connect with the pedal. The base of the 4 mounting studs to the end of the threaded pedal rod is cut down to 4 inches.
Should I try to have the backside rod cut, shortened and welded? I can't find any booster that has the length of threads I need. Help! Any ideas would be great.
I don't need the adapter. The PO already cut the firewall and replaced it with 4 holes so no adapter needed.
I thought the adaptor creates the spacing necessary to use the mini truck booster, regardless of the rib.
Splangy, I love ya but you need to re-read the original post.
The ribs aren't an issue whatsoever. The minitruck part is an irrelevant detail.
The issue is that the threaded rod coming out the back is way too long. I need to cut it so it's about 2-3 inches shorter. A spacer will do nothing as it's only 2cm. I need 2 inches but the threading would be cut off the minitruck booster if I shortend it to the length I need.
So, do I take it somewhere to be cut and welded or is there a booster out there that is essentially all threaded rod on the back that I can simply cut?
I acknowledged the part about the rib not being an issue. The minitruck part isn’t irrelevant if the rod on the miniteuck booster is too long.
The adapter is a lot longer than 2cm. I believe the JTO part was designed to accommodate the extra length of the mini truck rod (and clear the rib if needed).
Maybe I’m still not getting what you’re saying, but it sounds like the booster rod is 2-3” too long and the adaptor is about 2-3” long. Sounds like it would solve your issue.
That threaded rod just pulls out doesn't it (you're referring to the rod that pushes the master plunger on one end and attaches to your pedal at the other right?)? Pull it out and replace it with your old one.
D
