I am trying to debug what I believe to be a combo of a bad O2 sensor and a plugged up cat.
96' LX-450. 151k Stock...
Are the 2 O2 sensors (One before and one after the 2 cats) interchangable? I believe my first one to be bad. The truck runs "rich" (strong exaust smell... poor gas milage) but it does not pull a check engine. (Could be bulb burnt out... ) I had the O2 sensor unplugged at one point and did not pull a check engine.
I also believe the first cat to be fairly clogged because it runs rough occasionally. Idles fine but at about 2k rpm on acceleration up inclines it will shimmey and shake sometimes. *Not all the time* feels like a back-pressure issue. Also it is not consistant. I am thinking of taking it off and punching a hole thru it to see if it runs better. If it does I know I have to do somthing with it.
Any help is appreciated..
Thanks,
Nick
Thanks,
Nick
