O2 Sensor Debug...
The first O2 is checking the mixture (lean etc) the second checking if your cats are working.
When my front sensor went (they usually go at about 100,000miles) - in terms of driving I got this.......
idle - no problem - because the ECU doesn't reference the sensor
wide open throttle (WOT) - no problem because the petrol is dumped in and agin ECU not referenced
part throttle - ahh where it gets interesting - huge engine shudder, very poor or no acceleration, feels like the throttle is knackered - this is due to the ECU referencing a faulty signal from the O2 sensor. It doesn't know how much petrol to inject.
I could get some sort of normal operation only by blipping the throttle until it would start to accelerate smoothly.
NO ENGINE CODES THROWN DURING THIS TIME!
New TPS did not solve problem, garage took it back off at no charge (labour only). I fitted a new O2 sensor and completely resolved the issue.
Hope this helps - although you don't seem to have exactly the issues I had, they do sound similar (just re-read your post) constant acc. would always sort itself out
Boyo,
Sounds like our issues are more alike. The studder at part throttle is what I get and feathering the throttle is all that will get me by.
Some days are better then others. Running a injector cleaner seems to help. I can only assume its the more complete combustion.
I will try putting a new O2 sensor in the front and hope it takes care of it. If not I will have to look at the cats. a 96' that has spent its whole life in northern USA is not going to be fun to take apart (cutting torch anyone?:eek:)
Curious.
From what I've read on MUD, yes, it does. Look at LT's MAF mod there, there is a lot of discussion on it in there.
How is your rear O2 sensor harness terminated?
Just crawled around under the truck and can't find any plugs or blanked off wiring where the second sensor would be on your trucks - strange one!
Boyo,
I tried the injector cleaner route too - I think any improvement is more a placebo effect lol
The studs that hold the sensor in place sheared off as I tried to remove it - ended up having to remove the whole of the front pipe to extract them and replace with M8 cap head bolts. I use a locking nut to hold the sensor plate.
The sensors don't cost much - certainly nothing like a cat - keep us informed
Update:
I got the new 02 sensor in but it did not fully fix the problem. Just so happens my neighbor has the OBDII computer scanner so I hooked it up. Misfire cyl 1,3,5,6 ....!!!! Put new plugs in and wires. Now it runs like new!! I checked the gap on the old plugs just for fun.. they were running .060-.070""! :doh:
While I was in there I electrical taped the crack starting in my Air intake hose:hillbilly: I am going to run it a few days and hook it back up to the scanner to see if I am pulling any more codes. I think I finally got this one figured out. Thanks for all the help.
Nick
