O2 problem
Houston
I have a 1997 Toyota Land Cruiser that I just bought. I have an 'engine check light on, the code is p0135 bank 1 sensor 1, which I have located. The sensor looks new, so I traced the wire and found that the wire has been rubbing on the drive shaft and worn down to the bare wire. Thinking causing a short. Question is, is there a fuse that blew which gives power to the O2, if so which one is it.
Thanks!!!!!
Thanks!!!!!
no fuse, how in the world it is rubbing the drive shaft ? do you have DENSO O2? if not you need DENSO OEM, BOSCH and others will not work.
When I bought it, I guess they change the O2 and didn't move the wires any from the drive shaft. How can I tell if they put in the correct O2? And where can I find the correct part for the least amount of $$$
Thanks for your reply
98 snake eater, the engine starts fine. Repair the wires and check engine light is still on. I guess I will go back to Autozone to recheck the codes.
You can "clear the code" by disconnecting your battery for a moment, say 5 minutes. CEL will be off until another code pops up.
You can "clear the code" by disconnecting your battery for a moment, say 5 minutes. CEL will be off until another code pops up.[/QUOTE
Grizzlygibbs,
I did disconnect the battery last, and I went to install the negative terminal the alarm went off and could shut the dran thing. It did Clear the code, got in the LC this morning the check engine light came back on.
Unless I can figure out that it is the O2 that is bad or not. I kind of don't want to just go buy one and spend the $$$$$ on a toyota O2 $200. I need the part number of a Denso O2 and see what it will set me back.
Thanks for reply
Ya know... search actually works on this site... :)
One example (searching for denso o2 in the 80 forum):
O2 Sensor - OEM vs Denso?
cheers,
george.
Don't sweat it El Rabbit. The search function is in the top right corner of the forum when you are near the banner. You can type in any string of words and narrow down the search field to the 80's section. I like to try to help people if I can, because I used to have the same questions and would be told to "search." Just return the favor when you can. George_TLC is an awesome contributor to this site and is full of a wealth of knowledge. The link he provided contains the same information I gave you.
:flipoff2:Welcome to Mud!
Thank You!!!!!
I will try the search thing in the future.
I bought two LC and trying make one. From the interior to a engine swap. So needless to say I will be on this sight for a while. Thanks again to everyone!!!!! Even Geroge
Lots of good info on engine swap and what to look for/etc by using search. You can also start your own thread to document your progress and ask some questions. Generally people like to help out on this forum, but lots of stuff gets asked over and over and is easy to find.
Yes, I tried the search window to find the cup holder that fits in the empty space on top of the radio, and would you believe "it worked"
Thanks for your help and patience
Sorry you had to go to the trouble @euclid . According to Amazon it was a direct fit.
