Heck, that's an old school used car trick. Saw dust to quiet down the gear noise until it leaves the lot.
If I don't sell my FJ40 this year, I'm going in search of a NOS H41. It would be great with the Orion and all Toyota.Too bad the USA didn't get H41s. Nice and short, decent low gear, perfect now. Maybe not in the day when they were daily drivers.
Might want to install a speedi sleeve on your parking brake drum while your at it if it has a groove from the seal from years of use.Ok, I think I’m gtg now. This morning I pressed the bearings on assembling the output shaft on the bench and verified I have .009 clearance for both the low and high speed sides.
I had a self induced one when I overtightened the output shaft nut with an impact. I forget what was wrong but I do remember it required $300 in parts and a trip to valley hybrids.
3:1 vs 4:1
Anyone get a 3:1 gear set and think it was not too low?
Anyone get a 4:1 gear set and think it was too low?
I know the 3:1 gear sets are no longer available but still wanted to get opinions. I am thinking of putting one behind a H41 with 4:10 axle gears and 33's
thanks in advance,
Rob
I think 4:1 is perfect honestly. 3:1 I dont think would be enough.3:1 vs 4:1
thanks in advance,
Rob
thanks Kurt! I saw you had the correct flanges but I did not see the shafts on the site. Do you mind sending me a pm on some pricing?Yes & yes. We see broken 10 spline front outputs occasionally and yes we stock the 27 spline front output and flange of your spec (driveline pattern) at Cruiser Outfitters. In most cases, any t-case we built be it an Orion or standard, gets fine spline shafts when practical.
