What? Not so loud, he'll hear you. It is a carefully cast collection of land cruiser parts with a light dusting of American steel.
In my limited experience, the twin stick set up totally rocks and I would never again use the stock linkage in an offroader. It is MUCH better, stronger, more direct, more flexible etc.
I'm running Orangefj45's twins in my FJ60 and it is one of my favorite mods. I do have one minor improvement suggestion that Georg and I can discuss later...
I concur on the well built twin stick. After installing the new shift rail from A/A my stock shifter was not going to do the job. I too likey the twin stick.
Georg, speaking as to the detents on the new shift rails from A/A. We found that the spacing of the detents was spot on, if you have a backcut high speed gear. If you do not have a backcut gear the collar hits before the ball seats in detent. Nothing huge just a note in case others have found the same issue.
I like my AA twin stick set-up, it has a lot more positive feel than the OEM ever did.
After some tweaking it shifts good enough I could use it if I needed to. I think I've got a plan. Twin sticks are for jeeps.![]()
i don't get that logic. call me too outspoken, opinionated, whatever.......at least i'm honest. not saying that you're not by any stretch of the imagination. i just plain don't get it. you want to run ruibcon and take the chance on an item that's easily taken care of? what if your linkage bends and/or fails on the trail?! not the kind of trail-plug i'd appreciate. preventable issues need to be dealt with before hitting the trail.
Maybe what I'll come up with that's more clever than that is a solid single-stick mod. We'll see. I've been known to hack on something just for the adventure, then give up and go with what's been tried and tested.
often times the mechanical linkage will meet it's limits when running an orion with the updated detent.
Which one is mine???
Georg, just outa curiosity, why did you not switch the other unit to fine spline outputs ?
Did you happen to measure the output shaft where the high speed gear rides ?
I am looking for what that surface measures on a new or very good condition shaft ?
Those cases look nice, is that an epoxy paint or powder coat on the lighter colored parts ? or just a krylon/rustoleum finish ??
As many of you know I have been struggling with the Orion popping out for many years.
With the incredible generosity and patience from Matt at AA and my third case the problem seems to be solved. From the diagnosis of my second case the problem seemed to stem from the thrust washer play in the intermediate gear. Not something I even checked since it came from AA installed.
Again I can’t say enough praise about Matt and AA with a very difficult customer.
Getting ready to pull the trigger on an Orion.
Any inside owners group advice before ordering?
If I was doing it over again, I would go with twin sticks on installation and not wait 'til later. YMMV. Be prepared for a whole new level of wheeling fun!
