'Nuther FJ45LV resto thread, '67 Central American model!
Dan, I e-mailed you and I think I'll take the heater stuff. That means I need ALL the heater control and the heater itself for an FJ45LV. Anyone have spares?
Here's the install of the "new" springs from Georg. It went much smoother this time around since it was all greasable pins and shackles already. Everything lines up right too and the springs are even the same side to side!! We replaced the old tired bent and stripped "U" bolts and spring plates too.
We are working on the body as well but need a small sheet metal brake. Has anyone used the 18" one from Harbour Freight? How about a "build your own"? I've already spent all my shop tools budget this year.
You are quite possibly talking about the largest piece of crap ever produced. This is the tool I used for my build and it only worked because the price was right. If you care about your bends and want your stuff not to look as bad as mine, spring for a different brake. I don't even know where to recommend you go, but it seems like you have things figured out down there and probably will find something with a little looking.
Good luck, and please I beg you....don't buy it. That would mean that Harbor Freight would need to order more inventory. Infact, I won't even give you mine to use/borrow. It sucks that bad.
Here is a link to my tools. Yes this 18" of raw crap is one of my tools.
https://forum.ih8mud.com/showpost.php?p=865659&postcount=68
Dave
Finally a year and a half later (and two major surgeries) I'm working on the LV again!! Today in shop class we tore down two Toyota CT-26 turbos which we'll salvage the best from and that turbo will go onto the 3B diesel which now resides in the LV frame.
I'll try and take some pictures as we reassemble the turbo and actually bolt it up.
Do you offer summer classes?
I would love to enroll.
I could donate a bender or sandblaster as tuition.
For a bender or sandblaster I might offer summer classes!!
Here's a few photos of getting the 13B-T manifold tapped for the pyrometer sensor and mounted on the engine. The turbo bearings were shot and the bearings in the rebuild kit were even looser than the old bearings! I sent it out to the machinist for new bearings and we should have it back in a day or two.
I found some 3B A/C bracket/idler and pulley stuff so I bolted that on today. Here's the "before the A/C picture" (I had the idler earlier and bolted it on so I couldn't loose it) and the "after the A/C parts" picture. 3B A/C parts are almost harder to find than LV parts!!
I hope to get the body back in the shop in the next while so I can continue working on that and maybe have it bolted on for good by the end of this school year.
We're working on the '45 body right now, cutting out rust, fixing dents all primarily along the bottom so I can get the body back on the frame for good.
I have a question though. In the latest Toyota Trails they talk about grafting a later model firewall/pedal bucket into the older truck for ease of installation of disc brake components. Has anyone done this?
Also, does anyone have good ideas for removing bondo? https://forum.ih8mud.com/paint-body/201121-bondo-removal.html#post2968051
I saw that article, thought about doing that. Some just relocate that reinforcing rib and fabricate the wall to accomodate the MBC of choice. If I was going to go to all that work I would just put it on top of the other. Definitely gives you the opportunity to utilize more readily available MBC an Clutch master. Looking good Charles.. still got a spare single barrel?
Do you need one? I have the one of of the 45LV though I doubt it's from the 45LV originally. If you're interested I can shoot some pics and bring it up in the summer. It ran last time I tried but if it were me I'd rebuild it.
Cruiser_guy
I did the firewall bucket swap in my lv it was a pain but well worth it. if you check my wilma thread I took some lame pictures of the process but it is there is some good info there.what I did was pull the exisiting pedal bucket and put the 77' one up ther eto see what was needed to be removed to have things clear then figure out how much of hte firewall had to be cut out.
Jason
I guess the drivers side firewall is my next purchase at the wreckers. They must wonder what me, a gringo, is doing with all the old 'Cruiser parts that folks here don't want!
Anyways, here's some photos of what my rear quarters and the rear sill look like after removing up to 3/8" of bondo! Am I looking fairly standard or am I better or worse than others?
I think the problem you are going to have is not what is on the outside, a bad repair, but what is on the inside that they covered up? Probably lots of rust. Since mine were open I was able to sand blast the insides pretty good and then cover them with primer.
Mark/Jason, how much did you pay for that portion of the firewall? The wrecker that I have been going to has a new management and they look at gringo's as walking cash dispensers! They wanted nearly $500 for the firewall from a squashed truck!!
Mark, here's a photo of the center arm as it is on my truck. There's a bit of surface rust as I do not have indoor storage and right now the body is in the shop getting worked on.
