My 80 failed the CO emissions on NOx. 4 gpm is the limit. It registered 4.98. EGR system is working. When the EGR system had failed a few years ago it registered 5.74. Two years ago when it failed due to a bad gas cap, it registered 3.14. 46 minutes later after having driven 2 miles to the auto parts store for a new gas cap it was tested again and registered 1.73. Obviously the tests are not consistent.
Since there is no obvious EGR problem to solve this time, is there any benefit to any of the following courses of action in a retest: (1) add a few gallons of Ethanol to the tank since allegedly ethanol burns at a lower temperature, reducing NOx. (2) turning off the overdrive and turning on the power button to keep rpm's higher during the test since I've read that higher rpm's reduce combustion temperatures and hence reduce NOx? (I don't know if the testers are required to make sure that the overdrive is on and the power button off)
There are three NOx peaks in the graph of the test they gave me on the low speed test and the high speed test. I assume these peaks are associated somehow with the shifting pattern. The peaks are steep on both up and down except for the last peak on the high speed test which plateaued for about 15 seconds before dropping. I'm hypothesizing that the peaks of NOx emissions occur when a shift happens, rpm's drop and combustion temperatures increase momentarily before rpm's increase again. (it would be nice if the chart included rpm's but it doesn't. It only includes mph) Perhaps the plateau of the third peak is associated with both a shift and the transmission locking up close together.
Any thoughts on these matters or associated tricks to passing the test would be appreciated. I'm still irritated over the fact that in 2008, the limit for NOx was dropped from 9 to 4 for my truck. It used to pass easily.
