It will all be done before lunch with me supervising!
You say some front teeth are shaved ? Like for getting the center pin in on the rear end ?
It's like when my tire bounced into the rock under power with enough force to make two lower knuckle bearings, a hub lock-out, and a u-joint explode. One tooth is about 20% shaved and the next is about 10%. The ring and pinion still operate smoothly but I think I'm gonna replace for good measure. Oh, and I definately have longfields in the front, needless to say, they are undamaged.
Darin is saying that with high aftermarket gears (4.88s, 5.29s), it's necessary to grind down a couple of ring gear teeth to get the center pin, that's necessary for a SF axle, to fit.
Did you see any metal shavings in the gear oil? If not, I'd just run it, especially if only two teeth are "shaved" and all other ring and pinion teeth are undamaged.
I can bring some pattern compound to check the pattern if you'd like.
Ahh, I did read somthing about that. Wasn't sure exactly what was supposed to be shaved. Didn't find any shavings but I havent wiped everything out of the diff yet. Johnny, perhaps when I get my locker I'll bring the third up to your place and we'll tackle it and drink some beers.
Thank you for clarifing it. I wonder if it was in the rear axle for a bit and that is why it was shaved down some.
plan on coming Saturday but I have to work until 1:00. Should arrive around 3:00. Meats, I thought you were coming friday?
Anyone who needs directions or an address can PM me for it. I think I'll be doing KFC or pizzas to make things easy. I believe we will be a relatively small group. BYOB and I'll have water and coffee.
My list right now: Finish plumbing for ARB to the compressor and check 100% for function; reassemble front axle; drill front transfer case flange and install driveshaft; install lockright in rear diff; install e-brake assembly onto rear of transfer case; install saginaw steering pump.
