What are your voltmeter readings????? Is the battery even putting out any volts?
commitments I had to take care of. Will check the volts tomorrow and will have the battery checked as well. I really appreciate all of the input.Battery shows 12.5 volts but I was told that a battery can show adequate volts but it can be bad on the amps. Thus having the battery checked tomorrow.
@RAGINGMATT
have you ever seen a amp rating for those RoHS terminals? They kind of look "flimsy" compared to the customary lead ones.
Your fuse box is still properly grounded... right?
Your battery negative is grounded to clean, bare metal on the PS franerail, behind the front wheel... right?
I still believe it’s related to your fusible link... I know you said you checked it, from the battery to the harness... how did you check it?
Loss of the fusible link (melted, burned, etc.) opens the WL circuit, from the battery positive to the ammeter and to the fuse box... no power.
If the fusible link is intact, is the connector to the WL properly connected? If the connector is not well crimped, sudden stops/starts can leave the WL circuit open... no power.
Check continuity from battery positive to ammeter and then to fuse box.
I replaced the terminals when I first purchased the truck.
Or corrosion inside the positive cable. The moving around of the cable and reconnecting may have loosened it up enough to work.Corrosion on the positive battery terminal.
Awesome. But what was the problem?
Curious, is the heavy white wire that powers everything that connects at the starter terminal where the positive battery wire connects actually connected there? I’ll expand my curiosity depending on the answer.
