No Start
rrv333
Weatherford, Texas
Good morning collective. Went to start the 40 this morning and when I cranked her, I didn't have my foot on the clutch and she lurched forward almost hitting the garage wall. After some colorful language for being really stupid, I went to start her again with my foot on the clutch and nothing, zero, nada. The 40 is not a daily driver so I thought maybe she needed a jump, nope still nothing. Prior to my ignorance, no starting issues at all. So please help a neophyte out. Thank you.
Need a bit more info. Do your lights/ radio work? If you went from a normal running truck and its now wont even try to crank it points to something electrical. Check your grounds and battery connections. Also take a look at your fusible link. Sounds like somthing popped lose.
Bummer, Ronnie. I agree with @BRShap , that sudden of a problem is likely to be electrical in nature. Battery terminals good and tight? If so, test test the battery voltage (wondering if lurch forward could have separated a plate connection inside the battery). If it's not even cranking the starter, check the starter cables, especially the ground.
I wonder if you just nuked your starter. Could be a [relatively] simple fix if everything else electrical is functional.
Didn't check the electrical was running late for work. I'll check this afternoon and then report back. Thanks for the input.
Could be, since there's a lot more load on the starter, turning over the engine as well as the drive train.
Definitely a lot more info is needed, time to get the voltmeter out and check things..
Nothing, nada... if that means, you turn the key and nothing... no sound, nothing.
Check your fusible link... make sure it’s good... make sure the connectors are good, in each end... make sure the connection to the harness is good.
Check your starter... be sure the wire to the spade terminal is still snuggly plugged in.
No horn and no lights. Checked all connections and everything seems securely connected. Will check the starter next.
Will do, thanks for the input. Took today off to address this issue.
Is your battery secured. A loose battery could of shifted when it lurched and pulled a cable out of a lug or loosened the lug on the battery post.
Battery secured. Waiting for the day to warm a bit before diving into the problem.
Corrosion on the positive battery terminal.
No corrosion on the the terminals.
Replaced the fusible link from the terminal into the harness; still no horn, lights or start.
Have you checked for voltage anywhere?
Ignition switch is where I’d look next. Do you have the means to bypass it to check power to fuse box?
This is a 76? So power doesn’t go through the ammeter first, or does it? And how’s the battery grounded (to what)?
Should still have lights without the ignition switch, no?
Do you have power to the fuse box?
