I can't speak to a 95 because I don't have the EWD in front of me but a 94 doesn't work like that. Pin 1 ground, brown wire. Pin 3 is other part of that circuit, gets +12v from the MREL pin on ECU. pins 2 and 4 are the switched circuit. 2 coming from the 15A EFI fuse, 4 going to the ECU, VSVs, IAC, O2 sensors, and Circuit opening relay, then on to the fuel pump relay, resistor, and eventually on to the fuel pump.
Anyone know of an easy way to post individual pages of a PDF?
Continuity - Between red wire on EB1 (driver side) and terminal 3 of EFI Relay - YES, checks out OK
Ground - I get continuity between terminal 1 of EFI relay and the negative battery post - YES
Voltage of EFI Relay terminals: (with black meter wand touching negative battery post) Key OFF
4-no...........3-no
2-12.1v.......1-no
Key ON
4-no.......3-9.53v
2-12.1v...1-no
The 9.53v on terminal 3, with key ON, matches the 9.53v I measured on the passenger side of EB1 plug, red wire coming from CPU
That all looks OK to me, so I cannot find where the problem is... It will not start with a new EFI relay in place, but it will start and run fine with the 4&2 terminals jumped...
Continuity check between the ECU connector terminal and pin 3 of the relay. Should read a short or 0 ohms (or close to it)
Reseat the connectors on the ECU.
Yes. MREL is the logic trigger for the EFI relay. Something is causing a voltage drop from the ECU to the relay. Either wiring/connectors or the ECU output could be faulty.
None of the voltage readings I gave most recently were with the EFI relay in place, but the key was ON. I'm not sure how to check with the relay in place as it covers up the terminals?
I would expect 9v to still trigger the relay just fine. Can you feel it snap or click when turning key on?
There are four connectors on the ECU.. This will be the 22-pin one. Yes pin 3.
Might as well check output voltage there at the ECU on pin 3 with key on. Neg probe of multimeter going to a non-painted bolt on the dash brace or similar should be fine.
My truck is half covered in wet bed liner at the moment or I'd check what mine shows at the EFI relay.
Something isn't right. I wouldn't expect the problem to be between the ECU and EB1 on two separate harnesses.. and resistance between EB1 and the EFI relay wasn't significant..
Need to check voltage output at that ECU pin. Or try a different ECU.
If you want to take a look at your ECU.. you can remove the metal covers pretty easily. Look for capacitors that have leaked electrolyte fluid on the board. My old 1KZ-TE ECU from the 4runner had this problem... though I haven't heard of much of it with the 1FZ-FE
You might be able to replace those if the damage is confined to components you can identify. Possible your old harness having issues is what popped them.
I replaced all of the caps in that 1KZ-TE ECU and it worked great.
I thought about trying that, but who knows what else may have popped on that board. It's the 2 light blue caps that are obviously burnt, plus the black panel right next to them has 2 spots that are melted. You cant really see that part in the pic. I've got a used replacement on order already, so a couple of hundred bucks to know it's right after I've spent as much as I have chasing this problem isn't too bad IMO...
Those are resistors, but who's counting. The black plastic "panel" is an IC, so that would need to be replaced as well if it is damaged. At this point, a replacement ECU is prudent. I would give Jason@cruiseryard.com a ring. @arcteryx is sure to have what you need.
Those are wire-wound resistors and designed to handle high current (compared to more common carbon resistors). The fact that they overheated means they were passing more current then they were designed for. So before you pop a new ECU into your truck, you should make sure nothing is wrong with your wiring. You have checked for continuity between pin 3 on the 22-pin ECU connector and pin 3 on the EFI relay connector, but I haven't read where you checked the resistance between either of these pins and ground with both the relay removed and the ECU connector unplugged. There should be no continuity (infinite resistance), since the wiring between these two points connects to nothing else. If you do measure some resistance to ground then you have a wiring problem that you need to track down so you don't end up burning up the new ECU.
I went through the replacement harness and fixed up any questionable spots I saw, but never checked it with a meter so I'll definitely do so now. Thanks for pointing that out.
What's the part number on the bad ECU? There were known problems with the 89661-60170 units used prior to May 1993, but since you have a '94 it should be p/n 89661-60221 and those were used until 1995 when the TCM and ECM were combined into one unit.
