No start, died while driving. Help!
How do I do that?
How is it related? I'm just trying to line all the possibilities up... I smell gas in the engine bay when it's turning over (but wont start), so that led me to believe the fuel pump was OK. (I've removed all EGR and charcoal canister stuff, so I always smelled gas from the vent lines).
It wont start with a new relay in place, but starts and runs with a jumper on the 2 & 4 contacts of the relay plug.
New development, I just put a jumper on the 2 & 4 contacts on the EFI Relay, and the truck started and ran without any warning lights.
When I put the relay back in, it wont start. It's a brand new relay! What does this mean?
Can I drive it with the jumper in place, so I can get my truck home at least?
You can drive it with the jumper in place, but if you leave it like that, the battery will drain.
If you're not getting +12 at pin 3 of the EFI relay with the key in the ON position, but the engine runs without issues with pins 2-4 jumped, then you have an open between the ECU and the EFI relay.
Connector EA2 by the fuse box on the left fender should have a solid red wire on pin 7. That is the logic from the ECU to the EFI relay pin 3.
It doesn't matter, if there is no power to the ECU, the fuel pump wont run.
Running with it jumper, not without, sounds like the relay isn't being activated. When the key is turned to run, do you hear/feel the relay click in? Does terminal 1 have ground? Terminal 3 power with the key to run is what kicks the relay on, bad wire connection? It can be run with the jumper, just remember to remove it when turned off.
IIRC, today when testing with the meter I got zero reading from pin 3 with the key ON. Also got zero reading from the big yellow/red wire at the connecter between the distributor and intake, key ON.
This whole time I've had Christmas lights, but they go away once it starts with jumper in place.
Jonheld- You are correct, no reading at pin 3, but it runs with 2&4 jumped. I left the EWD at work with the rig, but I'll trace in the morning to find EA2 and check it out.
The intermittent nature of the engine crapping out while driving (before it died for good) is what is confusing me. Could it be a bad connection under the fuse box on fender that worked loose? I've checked almost everything else, including replacing the whole wiring harness...
I would definitely check the wiring going in to the fuse box on the fender. I have seen a couple of instances where there was a short going in to the fuse box. Or melted wiring in the fuse box.
Obviously pull the jumper any time you don't want the truck running.. but outside of lack of ECU control of the EFI Main relay it shouldn't hurt anything.
Keep in mind that a jumper bypasses ECU control of the EFI Main relay.. so even with a new relay if you aren't getting the control signal the new relay won't trip and allow power. This is what terminal 3 is for. Give +12v to this.. even a small amount of amperage, and it triggers the relay to turn "on" terminals 2 and 4 which sends +12v to much of the rest of the system with enough power to run the needed components.
WHen you say no 12v at the yellow/red between the dist and the intake.. do you mean the yellow wire with red stripe? or red wire with yellow stripe? important difference.
Yellow w/red is what gets turned on by the EFI relay. So if terminal 3 doesn't work, you won't get +12v on Y/R. I bet if you check now that you have the jumper in, you'll see +12v there.
Terminal 3 gets power from the ECU. @jonheld would be correct if this were an OBDII truck, but the sig shows a 94, which will be OBDI. the "MREL" (main relay control) circuit doesnt go through EA2, it goes from the ECU, through the main engine harness, through the connector between the distributor and intake (EB1)
@ElCid04 check to see if the EB1 connector b/n dist and intake has +12v on the red wire on the passenger (engine) side of this plug. If not, your problem is between here and the ECU. Seems unlikely if you have a new engine harness...
Good catch. I wasn't quite sure about that connector, but same concept. I have a 91 and 97 so I took a guess at the connector designation. The circuits are identical with respect to the EFI relay other than the connector name.
Oh, and we didnt feel or hear the relay click when the key turns, even on multiple differents relays.
That equates to changing a light bulb to turn on a switch.
If the relay is not being energized from the ECU, then the switch is off. Changing the light bulb (relay) does nothing.
The connector name is important for troubleshooting in this instance though, with the circuit taking very different paths. The 94 has the MREL control circuit going from the ECU to the relay through the engine harness and EB1, the 97 through the dash and EA2 as you noted. This was one of the many inconveniences I had to deal with when combining 94 and 97 harnesses on my truck.
Either way, it sounds like we are zeroing in on OPs problem.
Ok so I going out to check all this again here shortly.
So far, I need to check:
*Red wire on EB1 to see if I have +12v on pass side of plug, to determine if problem is between there and ECU.
(This would not surprise me, as the "new" harness I put in was a used one that I went though to clean all contacts and repair the typical worn spots) I probably just should have bought a brand new harness for a 95-97 as they are the only ones still available, none left for 93-94...
*The 7.5a fuse in the dash panel, with key ON, to see if there is power.
I'll report back soon.
Ok, for the red wire on the EB1 connection, passenger side of plug, I read +9.65v on that spade with the meter grounded to negative battery terminal. Please tell me that means the harness I spent last Saturday installing is good!
For the 7.5a IGN fuse in the dash panel, I read +9.9v with both meter contacts on the contacts.
Both of these readings were made with the key ON.
What do I check now? I kind of seems like the problem may be in the wiring underneath the fuse panel on the driver side fender.
unhook EB1 and check for continuity between the driver side of EB1 plug red wire and pin 3 on the efi main relay socket. Pretty sure your problem is somewhere between those two points. Truck doesn't need to be on for this.
To properly check 7.5A IGN fuse, you need to pull the fuse and check for voltage on one of the terminals to ground. going across the circuit doesn't give true voltage, because your negative side of the circuit is wherever IGN circuit goes.. for this part the ECU. Hence 9.9v. Most likely one side to ground would show battery voltage or close to it, other side to ground would show no voltage. (Edit: I don't think the IGN circuit was your problem.. ECU doesn't know ignition switch is on if that circuit is faulty, which means it shouldn't run even with your jumper)
OBDI and OBDII 1FZ-FE harnesses are not interchangeable, so it's good you didn't get one of those. battery voltage on red wire at EB1 suggests your new(er) harness is good. Check for continuity between red wire on DS of EB1 and terminal 3 on EFI relay and get back to us.
EB1 - key OFF - My multimeter beeped at me and showed "0" when I tested for continuity between the red wire on driver's side plug, and pin 3 of EFI relay. That's means there is no break, correct?
7.5A IGN fuse:
Key OFF - 0 voltage on either terminal with meter grounded to neg post on battery.
Right terminal of fuse - 1.739 ohms
Left terminal of fuse - 0.610 ohms (if that helps at all)
Key ON - Right side of terminal - 2.151 V
Left side of terminal - 12.13 V
Both readings with meter grounded to neg battery post.
What next? This help has been great, thank you!
Ok.. Correct, no break. So, if you get +9v or whatever on the red wire of PS of EB1 with key on, AND you have continuity b/n red wire on DS EB1 and terminal 3 of EFI relay, you should get same voltage at terminal 3 of EFI relay, and EFI relay should turn on. Double check ground on pin 1. But, if you earlier said you weren't getting voltage at pin 3 earlier, something isn't adding up.
Also make sure you have your pins correct. Though the fact that you are successful in getting it to run with a jumper means you are on the right track.
IGN fuse sounds appropriate.
10-4, I'll double check the pin 3 voltage reading, and the ground for pin 1 in the morning when I get back to work. Would a pic oof the bottom of the fuse panel help? I unbolted it today just to see, but nothing looked off. Although there a quite a few blank white wires, almost like one of the POs did some work to it.
On a side note, what should the resistance be for the 50A AM1 red fuse in the fender panel? I replaced it with the others when I first started this, but on a whim I checked the new fuse with my meter. I only read 0.1 ohms across that fuse. Is that correct? I cant find what it should be anywhere. Is that even related?
Thank you again, it feels good to be narrowing things down and getting closer to the fix
Most of the incoming wires to the fuse panel are white so that is normal. They start to get color coded after fusing..
A 50A fuse is so big it won't show much resistance, so .1ohm doesn't sound out of the ordinary. Besides, AM1 doesn't fuse the ECU circuit at all.. it does run the start solenoid and many of the accessories (power windows, locks, seats, etc..) if you had problems with AM1 i'd suspect further noticeable issues.
Any time.
BTW I get email notifications on PMs so if you are in a hurry to get an answer send one that way.
I'm looking at a 1995 print and the 1 pin should have voltage to ground, and the 3 pin would be ground. The ecu switches the ground. So I would check the voltage to make sure the direction of flow is right then make a ground jumper to the proper side of the relay and see if it will pick up the relay. Just thinking out loud.
James
