No start, died while driving. Help!
Fort Mill, SC
I have searched a lot, but cannot find an answer for my problem.
1994 TLC 235k miles
Never had any electrical issues whatsoever before now. I have noticed a squeeking from the front lately, figured it was idler pully.
Sunday I drove to the hardware store with zero problems like normal.
Came out, loaded my lumber in the back, started right up.
Stumbled for a split second pulling out of the parking lot, at the time I thought it was a weird shift...
Stop light to turn on to main road, engine died, everything else worked.
Restarted immediately and drove off while keeping revs up so it wouldnt stall.
.5 miles later I let off the gas pedal to go in to turn lane, engine died again. Restarted immediately while going 35 mph...
Came to a stop at the light, engine died again, has not started since. Got it towed home.
Turns over and cranks, doesnt start.
I replaced the fusible link wires today, thanks to Onur's over night package. No start, but cranks.
NO cel, but have Christmas tree. A/T oil temp, brake, water, and voltage lights.
I checked all fuses, all ok. Switched the EFI relay with the window one, no change.
Put a meter on the fuse spots in the fender panel, all show 12.6 volts EXCEPT the 7.5 amp fuse spot. I also cannot get a reading on the b+ spot on the diagnostic port, just shows zeroes.
I also do not smell any gas like I usually do, as I've removed all smog stuff and pair system. That was 30k miles ago when I did the HG job, and replaced the fuel filter. I know it has gas in the tank, only 110 miles since last fillup.
I went ahead and also replaced the alternator today, no change. I thought the previously mentioned squeel could have been the alternator instead of the idler pulley.
Assuming I grounded the threads correctly, I did not see any sparks flying from #3 when I pulled the plug out and cranked.
Fuel pump or ignition?
What do I check now? What causes no charge at the 7.5 fuse on the fender, or the b+ at the diag port?
Before I just start replacing stuff, how do I narrow it down?
Not sure on the fuse thing but first thing I would do is put a fuel pressure gauge at the top of the tank. The access panel is under the rear seats. Just do a search, you pull one of the seats and pull the carpet back and remove a half dozen or so screws. You can borrow the kit free at Autozone. When I checked this out on my 95 and found the fuel pressure not holding, the hose on the pump itself had actually worked loose. I put it all back together and bent the ears up on the bottom of the assembly to hold the pump in place tighter, never a problem afterward.
Aside from the fuses (again I have no idea) it sounds like a classic fuel pump issue to me.
Check the wiring harness where it crosses the EGR pipe by the firewall and where it connects to the ECU behind the glove box. Its known to melt/abrade in those locations and cause electrical issues.
Forgot to say, all of the meter checks I mentioned were with the key ON.
To confirm, NO cel with key on, only 4 mentioned lights.
Also forgot to mention that all those lights go off when I'm cranking it, they only shine in ON position.
The egr pipe was removed when I did HG job. Blocked off now, and the harness is in good shape.
Obvious question, but I had a friend with a bad fuel gauge. Turned out he was just out of gas. Your description matches running out of gas exactly. Any chance you could be this lucky?
If you DO NOT have a CEL when you try to start it you are not getting power to your EFI. The vehicle will not start if you are not getting power here. Period. No CEL = No Start.
You need to diagnose this. First, pull the 15amp EFI FUSE that is in the fuse box under the hood. Replace it with a new one. You are not getting power. You may have a fuel pump issue as well but if you are not getting power to your EFI it will not turn on the fuel pump. The fuel pump being bad WILL NOT give you a "No CEL" diagnosis. This only comes from not getting power. Change the fuse. Report back.
Ok I will check that after work and report back. I could have sworn I got a power reading on the 15A fuse when checked with my meter last night, but I checked so many things that they are blending together. The only one I specifically remember NOT having power is the 7.5A fuse right next to the 15A you mentioned. But I'm not sure if that gets power anyways with the key in ON position...
I doubt it matters, but a visual inspection of all the fuses checked out, they all looked good. I will replace it anyways.
Do not trust a visual inspection. Pick up a box of fuses from AutoZone. Replace with new. If the new one doesn't change things. Try another one.
Personally I have had that fuse "blow" and it look just fine. Replace with another and nothing. Replace with a third and it works fine.
It's a good idea to keep spare fuses, a spare EFI relay, and spare fusible links in your 80. They are cheap. Like $25 for all of them. Nothing worse than one of them going out in the middle of nowhere (or anywhere for that matter) and not having a simple, inexpensive, quick repair.
Let us know your findings.
No CEL and no power to the B+ means no power to the ECU, etc.
Do you have battery voltage at the EFI fuse, if not it's between there and the battery, fusible link, etc.
If yes, remove the EFI relay, do you have battery voltage at terminal 2? If no, the problem is between there and the fuse.
If yes, turn the key to run, do you have battery voltage at terminal 3? If yes, install the relay, have a helper operate the key, does the relay click each time the key is turned to run?
If yes, look between the distributor and intake, there will be a connector (IIRC 2 terminal) one of the wires is yellow/red and big, disconnect the connector. With the key to run, it should have battery voltage. This connector has been known to fail, have replaced/repaired several.
It's aliiiive!
I replaced every single fuse in the engine bay, but that didn't fix it. Although now I have 18 sets of spares for every fuse in my rig...
So after I changed the fuses and it didn't start, I climbed up on my bumper to take a closer look at the connections between the diag port and fuse block. As soon as I put my hand on the firewall/wiring harness to lean in closer, I heard a click...
Turns out that the wire loom has at least one short near the old egr location. I went through it in detail when I did the HG 18 months ago, so I was stumped as to how it could fail now.
Then the lightbulb went off... I must have squished the harness when I jacked the engine up to replace the motor mounts a couple months ago while chasing a vibration.
Although moving the loom around yesterday didn't help, after following LS1FJ40's advice to replace the fuses tonight even if they look OK, I'm guessing I had both a short in the loom and blown fuses.
In hindsight, blown fuses following a short in wiring sounds suspiciously like common sense. Although anything electrical seems like dark magic to me, someone smarter than me probably designed it that way. Call it a hunch...
Thank you for the help Gents! Glad I waited on ordering more stuff...
One last question regarding the wire harness. If I replace it with a new one now, will I be able to use it with the v8 swap I'm doing this spring? Or am I going to be buying a custom one for the swap? I've saved the electrical parts of the swap for last, so I havent dug in to that info yet.
You'll be throwing away the vast majority of the new harness with a v8 swap. A few power wires, oil pressure and water temp signals, a few odds n ends.. Other than that it'll all get cut up and thrown away. Personally for the money I'd repair yours. With an EWD it isn't too difficult to figure out which wire is bad to narrow down what you are looking for once you open it up.
The actual repair will probably require some skills with soldering.. If you aren't experienced in this it'll be a challenge.. But another option is to lay a new wire/s over the harness to bypass what went bad and tape it all up.
I am back at this problem, turns out replacing the engine harness with a new (used) one did NOT help the problem...
I am going through these steps by Tools R Us, and here's where I'm at.
I have voltage at terminal 2. When I turn the key ON, I do NOT have voltage at terminal 3. Putting in a brand new relay did nothing.
What do I do now that I do NOT have voltage at terminal 3 (listed above) with the key ON? Also, I do NOT have voltage on the big yellow/red wire at the connector between the distributor and intake, which I'm guessing is related to NO voltage at terminal 3.
I've replaced the relays, ignition coil, alternator, and engine harness, but it still will not start. It will turn over all day, lights, heater, radio all work. No CEL, but I am still getting Christmas tree lights.
New development, I just put a jumper on the 2 & 4 contacts on the EFI Relay, and the truck started and ran without any warning lights.
When I put the relay back in, it wont start. It's a brand new relay! What does this mean?
Can I drive it with the jumper in place, so I can get my truck home at least?
