No start, died while driving. Help!
Great advice on checking the harness to ground.. I'd even take that further to the point of opening your old harness and look for bad spots. Yes, you can test the MREL circuit to ground, but with all the possible combinations of other problems that cooked an ECU on a harness with this many wires testing every combination could be really time consuming.
Technically a problem in the dash harness could also cause problems with the ECU, but the EGR area is far more likely. Meaning your newer harness is probably safe, but it's worth looking into.
Is it possible that the combination of a shorted harness (my original one), an alternator wearing out (I replaced it and my lights got brighter), and bad efi relay and fuses could have led to the ECU getting shorted? Or is it more likely the ECU went bad first?
I'll be going through the ground checks tonight.
I have a 95 LC and last week I experienced the same issue as EICid04 ..Engine cuts out while driving and no CEL when trying to restart. I am just getting started trying to figure out my problem and this thread has been extremely helpful to me as I try to get to the bottom of the issue.
The first major check I did after reading all of the post was to turn the key on and checked the voltage at pin 2 at the ECU which registered 12.2 volts. I then measured the voltage at pin 3 at the ECU and registered 0 volts (with key on).
Would this be enough evidence to conclude the ECU has expired?
Thanks in advance for any advice /comments
The surest way to check is to unbolt the ECU from behind the glove box. 3 mounting screws and 4 connectors to pull. Then unscrew the cover and look for burned components. Mine was obvious at that point that is was burned.
All my wiring checked out OK as recommended. I got my replacement ECU installed tonight and she fired right up and runs like a top, finally!
To summarize....
Learn how to read and follow the EWD. This will save you from throwing parts at it like I did at first...
But at least now I know my wiring harness, alternator, ignition coil, fuel pump relay, fuses and relays are all good for another 230k miles!
Glad to see you back on the road again! I am hoping to there soon.
I did check the condition of the ECU but I did not see any obvious damage of overheating or other damage. I will go through the full trouble shooting procedure as you recommend before making any major purchase(ECU).
By the way did you get a used or remanufactured ECU?
Thanks for the feedback
Highly unlikely. The Toyota ECUs are very robust and there have been few real failures documented here on Mud with the exception of the pre 5/93 89661-60170, which had known problems with 83+84+85 codes and was covered by a factory recall. They have protective circuitry built in and connecting an ECU sensor input to either ground or +12v should not cause a problem. (But do be careful when welding on your rig that the welder ground is as near to the arc as possible in order to avoid current-loop induced voltage spikes.) As much as I hate to say it, I think your number just came up and you got the short end of the straw.
Glad you are back on the road! :clap:
Henry - I picked up a used ECU from Cruiserparts.net, and it works like a charm.
I actually picked up a second one from a local yard while I was waiting for theirs to deliver because I got impatient, so I'll be putting that up on the classifieds soon.
Too bad you have a 95, otherwise I'd send you my spare...
Be sure you are using the correct connector on the ECU. There are four, and the one you need is the 22-pin. Wire should be red. If you are actually getting 0 volts there.. check pin 1 (black/blue). This is the wire that comes from the ignition switch and "tells" the ecu that you want the engine to run.. without it working it won't know to give voltage to MREL/pin 3. Pin 1 should get +12v any time the ignition is in ON or START. Just for info this circuit is fused after the ignition switch by the "IGN" fuse in the interior fuse block.
Not that we don't want to help, but I'll emphasize @ElCid04 point about getting and learning how to use an appropriate EWD for your year model truck. It completely transforms the knowledge base you have to operate on with all of this troubleshooting info.
Also, learn from my experience. Don't just get the manual, flip to the relevant page and start digging. Reading the "how to use this manual" is a VERY good investment in time.. it shows what is important, what isn't, and explains that a lot of the info you'd normally skip over not thinking it is relevant is actually HUGELY valuable data in other parts of the manual.
I am back on the road!
Took the advice of EICid04 and bloc and went through the EDW and found that my problem was a partially severed fusible link cased by the battery not being fully secured sliding in its case and cutting into the W-R wire that feeds the IGN switch..I got ahead of my self by first suspecting the ECU since I had the identical symptoms that EICid04 of "NO START died while driving". Learned a good lesson that when trying to figure out an electrical problem go to the EWD first.
Glad you got it working.. and probably learned a few things.
