^ Thank you
I got an email full of good questions, so I am reposting the questions and my answers here...
I will do my best to answer your questions...
How is the drive compared to stock 80 series as far as acceleration is concerned?
My cruiser will out-accelerate a stock cruiser with ease, and I would think it could outrun a TRD SC'd 80 series as well, although I have never driven one to compare against for sure.
How does it perform in low range in off road situations?
It performs just as well if not better than a stock cruiser. There is so much torque available in third gear that a light throttle application is sufficient to spin all 4 tires when on a loose surface.
Can cruise control be added to this set up?
Yes! I have all of the necessary parts, I just have not gotten around to it yet.
How are power windows working on this cruiser?
They all function, but are slow in the winter.
Yes, there is a yellowbox speedo correction on the speedometer, the coolant temp and oil pressure sendors were transferred from the toyota engine, the tachometer is 10% off, but good enough to get an idea what the engine is doing. The fuel gauge works, but for some reason is slow coming back up after a refill ever since I installed the long range tank. The voltmeter works perfectly, all idiot lights function properly, and I added a glow plug indicator light as well as a high-EGT warning light that can be set at an user defined level (currently at 1300*F)
None whatsoever, the electric cooling fan is controlled by a thermostatic switch and functions autonomously.
Any motor or tranny or diff leaks?
Yes, the rear main seal leaks. I have a new seal and plan on installing it next weekend (not this weekend) when I repmedy the park situation in the trans
Do lockers work as factory?
Yes, even thought the truck was not factory equipped with lockers, it is wired up and functions exactly like stock with all stock components.
Yes, but no pin-7 mod
Does tranny shift smoothly, etc?
The transmission shifts perfectly smooth and functions flawlessly.
Also, I just purchased some lightly used 315/70-17 BFG All Terrains and FJ Cruiser Steelies. I will be installing them on the truck this weekend and taking updated pictures.
