New steering issue
... You work on a lot of OTHER PEOPLE's trucks. Your job is to get them in one door and out the other, hopefully correctly and quickly to make the $$$$$$$$$$. ...
We are not a "shop", almost all of the rigs we work on, we wheel with, so mission critical to getting the our job done. Correctly is the first priority, breakage on the trail is failure, takes time from the job at hand. We only have one door. Making $$$$$$$$$$ is a nice fantasy, but as a volunteer origination, many of the owners are retired, fixed income, etc, so not so much. Pretty much, the whole thing is done for the love and betterment of OHV recreation.
I crank it back and forth a few times, turn it on, let it foam and whine for a sec, turn it off, wait, then refill and rock out
Most of the time, we just drive on. Often have little choice, under those conditions there isn't likely to be a handy flat spot, sometimes getting out of the rig isn't easy or safe?
The FSM procedure (read it a long time ago, don't remember it clearly) is designed to positively assure you that there is absolutely no air in the system- and if I recall, it doesn't really work all that well anyway. In real life, air is introduced all the time into the lines, and goes away all by itself, and doesn't noticeably affect the steering other than whining a bit and maybe a smidge of feedback. If this issue was related to air in the lines, it would not have a pattern- the looseness, firmness, tightness, whatever would be random.
One thing to consider, if the issue is after the steering box, it's a major problem if it can be felt at the steering wheel. It's not going to give feedback if it's a trunnion bearing or notchy knuckle- the mechanical advantage is too great. I'd start by disconnecting stuff until the problem goes away, and isolate it that way. Relay rod, tie rod, rag joint, steering wheel, driver...
I've never starved the pump at angle but I "extended" the reservoir substantially by cutting out the bottom of it and welding a 6" 2.5" ID tube to the bottom of it. It holds a lot of fluid in a vertical column now. And looks ghetto.
Appreciate the response. I’ll do all the procedures you just mentioned. As far as the urban wheeling is concerned I did it to try to get around to a front of a car with a dead battery. There was a fence so I could not just simply drive it forward. I had permission to do what I did. We ended up having to roll the dead car backwards and block traffic. It was just a fun attempt I thought I could do. Not the brightest idea but I did have permission. Thanks for the response I’ll take all those steps tonight. Thank you!
I love urban wheeling. If the zombies come, I look forward to at least driving my cruiser through some abandoned cities and negotiating the rubble.
Sorry. From your posts, I thought you did it for a living. Either way, you have way more experience on these than I, but I also know there are nuances to many and shortcuts to many more.
Thanks.
So little update. Just looking around the cruiser with it up on jack stands I can’t seem to find anything wrong except one thing possibly.... I noticed my steering stabilizer is making a lot of noise. It like creaks when turning the wheel. And this is with the car off. I do not remember if it use to make noise but is it normal for them to do this or did I maybe blow it out? It’s only a year old and OME but everything else looks 100% fine as far as I can tell so far.
Thanks!
Thanks!
Maybe the nitrogen on one side leaked out so its acting like an air spring?
