new ring and pinion advice
sittin on the couch in UT
okay just ordered me chromoly shafts now time to get new r&p while im in there
going to run 35 and maybe 37 if i can fit them.
im thinking 4.88 maybe even 5+ anyone have some advice and best place to get some.
also i have no idea how to setup for backlash and all that, should i have someone install them for me?
thanks
76 fj40
4:88's will be fine.
Have someone install them if you do not have the tools....and an FSM(not haynes)
READ THIS <--- this is a link
Very good write up by pinhead on ring and pinion set up...
One tooth on the rear gear set ring gear will need to be ground down to allow the spider gear pinion shaft to be able to be removed from the carrier to provide for c-clip install and removal.
5.29's are not needed, and you have to remove too much of the tooth for my comfort with a semi-float axle....
Order two new fine spline companion flanges with the gear and bearing kits...and a couple spare crush sleeves if you are going to do them yourself.
Or just pay someone to build the diffs for you.
Good luck!
I just did an R&P and was told to grind a tooth so the spider gear shaft would go in. After studying the situation for a while I found that the only thing that held the ring from dropping over the whole cluster was the spider gear shaft that protruded a small amount on either side of the housing. I took my 4" grinder to the ends of the shaft until it was flush and "viola" ring dropped right on.
Grinding a tooth probably doesn't hurt it, but with just a little more effort you don't have to.
While this will work for free floating axles, like the front, it won't work for semi float C clip axles, because the pin has to go in after the ring gear is installed.
If you have never set up a ring and pinion before, it may be best to pay someone to install them because it is the kind of thing that you tend to screw up the first time. It takes a lot of care and patience to get it right.
Or do like me and learn the hard way. Took me 2 tries to get my first one to work. The second went a little better. Still wondering what the heck I did to that third one I messed with. And it's the one with the ARB. Shizer. :eek:
Pay someone to do that has experience, preferably a shop. When/if the gears strip or it break you can have them re-do it if it is a defect in workamnship.
My buddy is pretty darned thrifty so he installed a deeper set in his TJ himself. They lasted about a month. He then had to buy a whole new set up and his wife made him have a professional install them.
When they break it is generally a tow ride home since it locks up the dif.
Not fun.
