New kid on the block+ To do list- update 31/05/2026
yep, a lot of work is already done by the PO
Now doing some little improvements to make it an almost daily driver
It's real fun to drive, you go slow(er) in everything
other drivers need to accept it, as it is what it is lol
very nice :)
That may be a good thing for you given that the speed limits in the Netherlands are insanely low. I just came back from vacation there and received 3 speeding tickets in the mail plus a fourth one from Belgium. Argghhh. :frown:
owww, this is for NL Administration a money maker
you can use Flitsmeister to see where actual controles are placed, including traject-control
For that speed sh*t I sold my BMW M1 and went to Amarok 😒
Nice 40 and a nice PTO winch 👍
Look like the tub was repair with flat metal, that is why it look like an aluminum tub
One more thing in your "to do" list
- rear drive shaft is out if phase
owww, that was not expected
Can you show me how I see this?
It can cause vibration but this is an easy fix .
Remove the driveshaft from the t-case side , (you should be able compress the slip joint so the yoke is out of the studs on the parking brakes )
Separate the slip joint and clock it so the two yoke are in the same plane , bolt back in place
You may need to remove the grease zerk on the slip joint to compress it
Nice looking rig. However, I also think anti-reversion shackles are upside down?????
I understand thx
The PO just told me it has been checked, and the body is higher than standard
Might want to unscrew one of your lug nuts on both front and rear axles, and then count how many turns you have before the nuts are tight. Aluminum wheels are notoriously thick, often not providing adequate thread contact for the lug nuts. Fortunately, longer wheel studs are available.
Thx for mentioning:)
how long would be a good minimum?
Hi guyys,
Yesss, my wife and I did it.
Buy a BJ40, and what a fun to drive it.
Body off restauration, including engine etc.
There is also a to do list (update 22/03/2026).
Some main issues:
-Anti reversal shackles in correct position
-Noise killing insulation
-Middle arm rest
-Driver seat lock not working
-Parking heating
-Wipers fast switch not working
-Flasher high headlight not working, although continue high headlight ( push hendel backwards) is working
-Shackle D-shape + mounting plate - in progress
-Anti start cable harness Cruiser Cult - in progress
-Fuel tank capacity 110L - in progress
-Middle arm rest - in progress
-Not all dashboard lights working - in progress
-Towing hook - fixed
-Running day lights front- fixed
-Backlights not working- fixed
-Ignition lock not always working - fixed
-Wiring and wiring harnas engine bay was not an attention point of PO - fixed
-Window hendle is in my knee, need to give it another position - fixed
-Led lights front - Fixed
-Interior light led - Fixed
-Reverse driving lights beam - fixed
-High beam lights - fixed
-City lights to led - fixed
-Strong claxon - fixed
-Driver seat not shifting
-Extra back interior light - fixed
-K&N filter - fixed
I guess some help is appreciated in time.
Looking forward to hear from you:)
Greetings from the Netherlands,
Roger
Good lights :)
