New kid on the block+ To do list- update 31/05/2026
Netherlands
Hi guyys,
Yesss, my wife and I did it.
Buy a BJ40, and what a fun to drive it.
Body off restauration, including engine etc.
There is also a to do list.
Some main issues:
-Anti reversal shackles in correct position
-Power convertor 24V-12V for radio and power steering not working
-Now Starter motor not working, and no power from start relay
-Noise killing insulation
-Middle arm rest
-Driver seat lock not working
-Parking heating
-Wipers fast and park switch not working
-Shackle D-shape + mounting plate - in progress
-Anti start cable harness Cruiser Cult - in progress
-Fuel tank capacity 110L - in progress
-Middle arm rest - in progress
-Not all dashboard lights working - fixed
-Flasher high beam light not working, although continue high beam light ( push hendel backwards) is working - fixed (see other posts)
-Towing hook - fixed
-Running day lights front- fixed
-Backlights not working- fixed
-Ignition lock not always working - fixed
-Wiring and wiring harnas engine bay was not an attention point of PO - fixed
-Window handle is in my knee, need to give it another position - fixed
-Led lights front - Fixed
-Interior light led - Fixed
-Reverse driving lights beam - fixed
-High beam lights - fixed
-City lights to led - fixed
-Strong claxon and wiring - fixed
-Extra back interior light - fixed
-K&N filter - fixed
I guess some help is appreciated in time.
Looking forward to hear from you:)
Greetings from the Netherlands,
Roger
Looks nice. Start reading almost every issue has been posted and solved. You can rebuild switches. Take all electrical connectors apart . Clean both contacts and inspect the wires at the crimp - corrosion can crawl under the insulation.
free download manuals will help.
Good question, not sure..., just bought the BJ40
can you show what it should be like ?
Ahhhh, just saw a picture on the internet
I see it, point taken
Another topic on my list:)
-window hendle is in my knee, need to give it another position
That's an easy one;
What year is yours?
That's an easy one;
What year is yours?
LoL, if you know all is easy :)
I told my wife, when working on a jaguar xj6-1970, nothing goes fast or easy
getting this crank Handle was the perfect example for me again
That's an easy one;
What year is yours?
It's a new build one
from 1977, Serie 4
engine 3.4 with disk brakes front
4 gears
original dutch delivery
with original factory winch
@Rogerr
Welcome to the madness !
Can you post more pics of the rig?
ofcourse :)
I'm adding some adjustments
when ready, pics will follow :)
Hi guyys,
Yesss, my wife and I did.
Some main issues:
-Wipers fast switch not working
-flasher high headlight not working, although continue high headlight ( push hendel backwards) is working
-Wiring and wiring harnas was not an attention point of PO
Roger
My to do list (18/01/2026):
-K&N filter
-Flasher high headlight not working, although continue high headlight ( push hendel backwards) is working
-Middle arm rest
-Install reverse driving light
-Strong claxon
-Parking heating
Done:
Interior light
Driver Window crank handle
Led head light
Tires pressure
Thx a lot, found already some nice reading info
Now digging in the forum, tons of info available :)
Wow that is a brand new truck!
yep, a lot of work is already done by the PO
Now doing some little improvements to make it an almost daily driver
It's real fun to drive, you go slow(er) in everything
other drivers need to accept it, as it is what it is lol
very nice :)
