new intake tube
Sandy Utah area
Any brands to stay away from? There are plenty of $30 amazon options and some have decent reviews. Don't really feel like spending $100 on a rubber hose.
I bought a cheap one one on Amazon. It fit fine. It doesn't leak. It's thinner and a little flimsy compared to Mr. T's. I'm sure it won't last 24 years like the original did, but it seems okay. Better than a leaky original sucking unmetered air, leaning out your engine and causing serious harm.
I fought the cheapest one I could find on Amazon. Fit and finish were fine. If you had to replace it every year, you’d still be okay.
Freudian slip or what you really meant?
Fought or bought?
Cx racing makes a nice stainless one! Fits perfect!
That looks very rigid. The engine vibrates and moves, you want some flex in anything that connects the engine to the body/frame.
Connected by silicone sleeves. Allows some flex
Not enough for me. The engine torques itself around. That setup might be okay for vibrations, but I'd expect trouble down the road sometime, especially if the truck is wheeled. It might be fine, but I couldn't trust it. The boots might eventually tear, or the mounts for the air cleaner mounting points will be stressed. That's just my $.02.
Maybe you have bigger problems like motor mounts if your engine moves that much?! :)
Motors move, and their mounts fail. Hey, do what you want, I'm just pointing out that there might be a reason the stock tube is rubber and has an accordion section. I'll bet someone makes pretty SS coolant hoses too.
I’ve used this SS one since 2014. No issues. Survived a rollover too. Can’t imagine anymore flex on a motor than that.
Because it’s cheaper than metal. And they made millions of them.
